Port sleeve mod?
Old Sep 27, 2002 | 03:01 PM
banzaitoyota's Avatar
What Subscription?
New line from the factory. Ask ROY_JAMES how well his JB weld sleeves worked. It cost him an engine. You do not need larger secondary injectors until you dyno out >200hp
Old Sep 27, 2002 | 04:01 PM
Liquid Anarchy's Avatar
We come with the Hardcore
mazdatrix sells new lines. $20 a peice.
The thing you think is causing your exhaust leak is the EGR. Ditch it. The S5's (or mine at least) didn't even have it.
Old Sep 27, 2002 | 07:43 PM
rotarygod's Avatar
Rotors still spinning
I've run plastic steel epoxy in my 6 port sleeves for several years with no problems whatsoever. My '88 had it for a few years and my GSL-SE currently has the epoxy in them. The glue should work fine if you cleaned everything first. I have plastic steel epoxy in my port runners on my turbo 4 port to help smoothen then out. No problems there either. $60 for Pineapples sleeves is too much when you can spend $5 on epoxy and do it with the same results.
24seven_dada
20
Nov 10, 2018 12:03 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
mulcryant
Sep 9, 2015 05:24 PM
