Curious to see what oil grade.......
Old Sep 27, 2002 | 07:05 AM
coolrotaries's Avatar
I wanted to find out what oil grade are people using in their single T setup. Should I be using straight up 50?
I am currently using 15/50 Mobile one, and I get about 30psi at idle. But when about a week passes by it lowers to 10psi. Can it be that it thins out so quickly? Am I not using the right oil? I was told to change back to regular oil, since thats what it came from factory with.
Thanks D
Old Sep 27, 2002 | 07:47 AM
AJatx's Avatar
I've used synthetic on my modified FC.
I currently use 30 weight oil (natural) for my single turbo FD in Texas.
J
Old Sep 27, 2002 | 10:03 PM
Bill B's Avatar
Castrol 20/50. Have used it in every RX7 I have owned. I never had an oil related failure.
Old Sep 28, 2002 | 01:04 AM
maxcooper's Avatar
WWFSMD
I have been using Royal Purple 20W-50 and switched to Racing 51 just because I wanted maximum protection. I have a "dry" turbo, so I decided to use synthetic. My oil pressure stays up longer with synthetic than it did with mineral oil, too. I don't have any data, but synthetic is also supposed to lower operating temps (water + oil), which can be an especially important issue for road racers.
There are many good oil choices available, and we don't often hear of oil-related failures with these cars. I think you just have to weigh the factors and make a choice.
-Max
Old Sep 28, 2002 | 04:26 AM
HWO's Avatar
HWO
inteligent extratarestril
I use Mobil 1 5w-50, i'm In New Zealand
Old Sep 29, 2002 | 08:39 AM
Hey guys I just changed my oil AGAIN, now to Castrol 20w50.
I now get about 15-20psi at idle(before just below 10psi) but what puzzles me is that the sweeping of the needle on the guage isn't smooth. Its more like jerking at around 50psi and above. Meaning it sweeps up smooth to about 50psi and then starts to go a little up towards 60-70psi, then back down acouple of psi's, then back up. What I'm trying to say is that its not smooth when the pressure increases. Sometimes it doesn't even go past 60psi. AARRRRR but sometimes it goes to 100psi!!!. Now I tried Syn oil heavy and light but results vary.
Any suggestions????? I'm currently using (4) quarts of Castrol 20w50 with one quart of Lucus oil.
The guage is Autometer 100psi.
Old Oct 1, 2002 | 06:50 PM
Taz's Avatar
Taz
The problem might be in the oil pressure sending unit. What's the oem gauge reading?
Old Oct 2, 2002 | 10:00 AM
amemiya's Avatar
I use royal purple 20/50 in my daily driver RX7 and royal purple racing 51 in my weekend RX7.
Old Oct 2, 2002 | 10:01 AM
amemiya's Avatar
at $10 a qurt for the racing 51 I am gald I don't put alot of miles on the race car.
rotor_veux
Sep 3, 2015 07:10 PM
bikeboy23332
Aug 28, 2015 02:02 PM
