what's the wire in the brake master cylinder?
Old Sep 27, 2002 | 04:31 AM
tweaked's Avatar
I noticed a little thing that plugged into the brake master cylinder. is it a heater or what? what is it's porpose?
Old Sep 27, 2002 | 06:29 AM
hIGGI's Avatar
there are two connectors shown in FSM according to brake master cyliner...one in reservoir is Fluid level sensor (u`ll get BRAKE light on if brake reservoir will be empty probably)
Old Sep 27, 2002 | 09:23 AM
DaleClark's Avatar
RX-7 Bad Ass
It's the brake fluid level sender - if the fluid gets too low, the Brake idiot light turns on.
Cars with auto adjusting suspension have an additional sender - it's a brake fluid pressure sensor. The AAS system can tell when you're on the brakes hard, and will adjust the shocks accordingly.
Dale
Old Sep 27, 2002 | 09:28 AM
AreExSeven's Avatar
Huh?
I think he may be referring to the brake booster line, with the way he calls it a heater?
Old Sep 28, 2002 | 04:52 PM
tweaked's Avatar
I am talking about the long black plastic thing that is stuck into the res. it has two leads in the connector. It goes all the way through the res, you can pull it out from the left side of rhte res if facing it. it can't sense the level as it never touches the fluid.
Old Sep 30, 2002 | 10:36 AM
hIGGI's Avatar
have you looked at picture i posted ?
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
