Question about Turbo's
Old Sep 25, 2002 | 11:30 AM
Windsor, Ont
Dont flame me for this because I am just learning but woud there be a difference if you just had a Bolt on turbo kit that dident tap oil from your oil pan but just from a seperate resivoir like a modified coolant tank. What if someone wanted to put a turbo in there car but not touch the engine in any way by drilling holes into the oil pan and they just needed a quick and easy way to get a turbo in there.. Would that work or will there be drawbacks? This way you can make shure your oil is always at a good level, clean, ect.
Old Sep 25, 2002 | 11:35 AM
nocab72's Avatar
03 Cobra Killer
Are you turbo'ing a currently non-turbo car?
If it is already a turbo car, you can use the existing oil feed/drain w/out tapping anything...
K
Old Sep 25, 2002 | 11:36 AM
Windsor, Ont
non turbo car.
Old Sep 25, 2002 | 05:09 PM
RacerXtreme7's Avatar
NASA geek
Sounds bad to me. #1 the oil volume would be small and would be saturated with heat in a quick amount of time due to small volume and it not going threw a oil cooler. #2 how is it going to be pumped? Your turbo is suspended in oil, this requires some positive pressure.
Old Sep 25, 2002 | 07:17 PM
rotarygod's Avatar
Rotors still spinning
A seperate reservoir would have to very big with its own cooling system. It would be faster to tap in to the cars existing system. You can turbo an n/a easily. Make sure you don't boost too high, have a good way of controlling the fuel and timing, and don't detonate.
Old Sep 25, 2002 | 08:15 PM
Windsor, Ont
Thanks everyone, I have an idea now.
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
