Power FC jerky at low revs
Old Sep 24, 2002 | 07:45 AM
CHRIS P's Avatar
jerky at low revs
I've had a power fc for about three months now and am really impressed with it, however at light throttle cruising it seems to go to injector cut and sort of kangaroo slightly as it cuts injectors on and off.
I thought this may be an incorrectly set throttle switch, but I checked the voltages and they seem to be spot on, the idle screw seems to be correctly set also.
Are there any adjustments or possible causes?
Thanks
Old Sep 24, 2002 | 10:08 AM
cewrx7r1's Avatar
Eye In The Sky
Use the ghost trace funtion to identify the cells, then add more fuel to them.
Old Sep 24, 2002 | 11:22 AM
Badog's Avatar
I just fixed a similar problem. Somehow, my injector accelerator settings had changed. All is good again.
RedBaronII
Sep 20, 2015 11:29 AM
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
localized
Sep 16, 2015 12:18 AM
