will catback raise my boost? (read before you tell me to search)
Old Sep 22, 2002 | 02:19 PM
jacobcartmill's Avatar
just dont care.
i was thinking about buying a catback system. currently i have a bonez 2.5 inch downpipe, straightpipe, and the STOCK CATBACK. i figured that i was "bottle necking" the exhaust.. my boost is only at a little over 7 psi with my current mods and i thought that it should be around 10-11... will a nice catback up my boost?
Old Sep 22, 2002 | 03:54 PM
Snrub's Avatar
From what I've been told and read in the past that the stock catback is a bottleneck once you've done the mods you've described.
Old Sep 22, 2002 | 04:08 PM
Ryde _Or_Die's Avatar
Ya a catback should raise your boost up some. If it doesn't as much as you want it to then you could do the TID mod. With just the fcd and walbro pump try to stay at 10psi or lower though.
Old Sep 22, 2002 | 07:47 PM
gigi's Avatar
aftermarket cat-back might give you about 3hp,stock one flows well,the spring on the waste gate looses a lot of tension when it gets old,therefore lower boost.
Old Sep 22, 2002 | 08:46 PM
I wish I was driving!
Old Sep 22, 2002 | 08:49 PM
just dont care.
Old Sep 22, 2002 | 08:55 PM
Originally posted by jacobcartmill
What is this for?
The stock catback is extremely restrictive. A gain of 10-15 FWHP is a more accurate number. And I am yet to see the wastegate being the reason behind a low boost problem.
Old Sep 22, 2002 | 08:56 PM
just dont care.
the .... was for the guy who responded before you.
Old Sep 22, 2002 | 09:03 PM
just dont care.
you think 15 whp from JUST the catback? i agree that they are restrictive, but that much even if i already have downpipe and midpipe?
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
msilvia
28
Apr 14, 2016 12:58 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
