Is the stock elbow thick enough to tap?
Old Sep 19, 2002 | 07:40 PM
Lost Time's Avatar
Chimera Driver
Question Is the stock elbow thick enough to tap?
I want to relocate the air temp sensor to the intake elbow, but I don't know if the plastic is going to be thick enough to tap. Any ideas??
Old Sep 19, 2002 | 07:44 PM
BlackR1's Avatar
Meesto Spakaro
should be thick enough to tap. Just put a rubber grommet in there to get a proper seal.
what are you gonna plug the hole in the UIM with?
Old Sep 19, 2002 | 07:56 PM
Lost Time's Avatar
Chimera Driver
I'm planning on leaving the air temp sensor that's in there alone (it's busted anyway). I'm just going to tap a new hole for the new sensor and run the wire around.
Old Sep 19, 2002 | 08:02 PM
BlackR1's Avatar
Meesto Spakaro
Do many people do this? I can see why it would be convenient, as those damn code 11's happen often... the thing I wonder about is if the intake temp is different in the manifold, than it is in the elbow.
Old Sep 19, 2002 | 08:06 PM
Lost Time's Avatar
Chimera Driver
Yeah, there's going to be a huge difference. The sensory, being in the manifold, has a tendency to heatsoak. By putting it in a plastic elbow, it won't have that same tendency. When you say use an o-ring, do you mean on the end of the threads toward the back of the sensor?
Old Sep 19, 2002 | 08:27 PM
BlackR1's Avatar
Meesto Spakaro
You're right, the UIM would retain the heat much longer than the plastic elbow. I was thinking about that but I had it backwards
Use the grommet like a washer, so that you wont overtighten it and risk cracking the plastic.
Sounds like a cool little mod. I might just take my IM off again to do that. Im thinking i'd place it on top, near where the TB connects to the elbow, as that area doesnt have much of a curvature.
Old Sep 19, 2002 | 08:37 PM
Lost Time's Avatar
Chimera Driver
I was thinking about putting it on the bottom side of the elbow just so there isn't any issues with hood clearance. But either way should work. You wouldn't have any clue what size tap I'd need would you??
msilvia
28
Apr 14, 2016 12:58 PM
djritz
Aug 25, 2015 02:46 PM
