whats the general boost for a 2nd gen RX-7?
Old Sep 17, 2002 | 11:40 AM
Rx7Rotary00's Avatar
by this question i was thinking what is the stock for a second gen RX-7 becuz i not sure what it would be pushing. is 12 lbs boost realistic? im absolutely lost...
Old Sep 17, 2002 | 12:06 PM
diablone's Avatar
I'd suggest asking in the 2nd Gen Forum. A search may provide the answer as well.
Old Sep 17, 2002 | 01:14 PM
eViLRotor's Avatar
Brother of the Rotary
Series 4, 87-88: 5.5 psi
Series 5, 89-92: 7.5 psi
12 psi is possible with the proper mods!
Old Sep 18, 2002 | 01:08 AM
NZConvertible's Avatar
I'm a boost creep...
According to the FSMs, peak boost is 6.56psi for the S4 and 8.25psi for the S5. In stock form, neither will hold this all the way to redline, which may explain why people keep quoting the figures above.
Old Sep 18, 2002 | 01:16 AM
NRA T2's Avatar
I've pushed 15
Old Sep 18, 2002 | 01:17 AM
NRA T2's Avatar
I neeeeed more fuel
Old Sep 18, 2002 | 01:41 AM
madaz07's Avatar
Pew Pew Pew
im using about 8psi on low and 14 psi on high. 14 psi at the limit of the stock injecters
Old Sep 18, 2002 | 01:54 AM
S2-13BT's Avatar
Mine spikes to about 14psi then settles at about 12psi. I use a manual boost controller, to increase the boost to these levels.
Without the boost controller I was getting about 5-6psi, which I think was reduced over stock because the stock IC is front mounted with some pretty twisty IC piping, causing a pressure drop.
Old Sep 18, 2002 | 01:55 AM
MtnRacer's Avatar
infini guru
12 lbs boost is VERY realistic. You're only a down pipe, mid pipe, and a cat-back away! Make sure and do your fuel mods or you'll pop your engine.
Steve
Old Sep 18, 2002 | 08:54 AM
How much CC's are ur stock injectors? Becuz the ones that come with the car i am buying are 550cc injectors...
Old Sep 18, 2002 | 11:37 AM
incendui's Avatar
stock are 550, and at 14 psi you should probably have bigger injectors, and definitly have some sort of fuel management controller, s-afc, a chip, etc.
Old Sep 18, 2002 | 10:09 PM
HIMNI Racing's Avatar
Rick James
you have pushed 15psi & 14psi , 12psi ? what the hell is this? all of these #s just flat suck. i'm not being a *** .. but i'm always hereing all this low boost crap. i've put my auto meter past the 20psi markwith no probs. Sorry for sounding x.
Old Sep 18, 2002 | 10:19 PM
Scott 89t2's Avatar
SOLD THE RX-7!
no offecnce but your HP number sucks LOL at 10psi with stock ports you should be making more then that.
Old Sep 18, 2002 | 10:26 PM
MtnRacer's Avatar
infini guru
You're not doing anything but pumping super heated hot air into the engine after ~15 psi. And a big turbo pushing 6 psi will generate more power than your stock turbo at 20psi.
Steve
The1Sun
Mar 18, 2018 11:08 PM
TerryD
Aug 23, 2015 07:40 AM
Seaweed
Aug 16, 2015 11:46 AM
