RX-7 Transmissions
Old Sep 16, 2002 | 06:54 PM
RX-7 Transmissions
I have a few questions for a Mazda expert.
How many different transmissions were used in 2nd gen RX-7's? \
How well do they handle full throttle shifting?
Do turbo & n/a engines use the same clutch disc & bell housing pattern?
Are the axle shafts & diff strong enough for 6000 rpm+ launch?
I am thinking about offering a kit to put a T-56 into 2nd gen cars.
Old Sep 16, 2002 | 07:03 PM
biorotary's Avatar
1) 3 trannys - manual for n/a, manual for tii, and auto for n/a
2) shifting at full throttle on a good tranny :o) awesome...
3) both the n/a and turbo uses the same bell housing pattern but the clutch discs are different in terms of thickness (from what i was told)
4) launching at 6k rpm? i haven't tried that...but i would imagine the tii's driveline should be able to handle it...not sure...
Old Sep 17, 2002 | 11:46 AM
Evil Aviator's Avatar
Rotorhead
Re: RX-7 Transmissions
The TII clutch is 235mm 87-88, 240mm 89-92. The NA clutch is 225mm.
http://www.mazdatrix.com/g1.htm
Note that the T-56 does not handle high-rpms well, so this would only be a good idea for low-rpm rotaries.
Old Sep 17, 2002 | 11:53 AM
OC_'s Avatar
OC_
I'm bastardizing my car!
dident the 89-91 N/A's have a turbo spec trans? i thought i read that somewhere.
could you put a 3rd gen trans in a 2nd gen??
Old Sep 17, 2002 | 12:31 PM
Rotorific's Avatar
I dont know a damn thing
no NA's dont have a turbo anything yes you can put a FD trans in an FC you will have to swap the flywheel and clutch unless you have a turboII and as for the driveshaft i dont know
Old Sep 17, 2002 | 12:50 PM
DaleClark's Avatar
RX-7 Bad Ass
The NA trannies aren't the strongest as far as holding power - somewhere in the 200hp range is where you start having problems.
The TII drivetrain is REALLY strong - the tranny can really take a lot of power and abuse. Once you get into the 400hp ballpark, 3rd gear can be a problem and can break - that's about it. The rear end and halfshafts are pretty strong, but don't cotton to wheel hop - that will kill a diff. Again, that starts to be a problem in the 400+ HP area.
Dale
Enzo1944
Sep 6, 2015 08:57 AM
