Huge Oil Leak
Old Sep 15, 2002 | 02:09 PM
MazdaRx7Racer4Life's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
Huge Oil Leak
When im parked its not so big, but this is new, when i turn on the car and rev it a bit, the oil pressure rises, and my oil comes streaming out of a hose. Im pretty sure its the hose that goes into the radiator, but i could be wrong, what else could it be, it looked like it was coming from that area. What a mess.
Old Sep 15, 2002 | 02:12 PM
Project84's Avatar
Open up! Search Warrant!
When you say the hose going into the radiator, you mean the oil cooler correct?
Old Sep 15, 2002 | 02:21 PM
yeah i think that's it, do you think it xan be that or something else?
Old Sep 15, 2002 | 02:43 PM
banzaitoyota's Avatar
What Subscription?
Fix it before you cook your engine
Old Sep 15, 2002 | 02:52 PM
88Vert's Avatar
I had a similar issue, but it leaked pretty bad when parked....it even started to wet the left brake and rotor.
The problem was the oil cooler hose started to separate from the end fitting. Arizona heat will work on an '88 like this. Replaced with MazdaTrix braided hoses. worked like a dream and looks pretty sharp and cheaper than OEM. While you're at it, check the oil filter stand. Sometimes the O rings starts to leak as well.
It will just get worse, so fix it ASAP. Good luck.
Old Sep 15, 2002 | 04:43 PM
thanks, im on it
Old Sep 15, 2002 | 04:50 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah losing oil is more than a nuisance. Its plain Bad, only one thing worse than an oil leak is a fuel leak.
rotor_veux
Aug 31, 2015 07:49 PM
Cameron38
Aug 19, 2015 06:08 PM
sypath
Aug 16, 2015 12:06 AM
