New HKS GT Wastegate !!!!!
The HKS GT II wastegate is the second generation of the high-performance 60mm HKS wastegates. Its new more compact design continues to offer the V-Band inlet and outlet flanges for high capacity exhaust flow for exceptional boost management.
Available at HKS Dealers soon. Please contact your local dealer for details and specifications.
- Reduced Weight and Size: 2/3 the weight (1509 grams compared to 2246 grams) and much smaller in height and width than the original GT Wastegate.
- Performance and Function: Identical exhaust flow volume rating, 60mm stainless steel valve and V-band inlet flange as the original GT Wastegate.
- Durability and Construction: Stainless Steel lower housing and Purple anodized aluminum upper housing.
- Flexibility and Versitility: Now available as one part number, The GT II is adjustable from 0.6 to 2.1 kg/cm2. Each kit comes with with (2) additional springs (2 built-in), to offer (4) different spring settings. Also included are the special tool and upper case design for easy spring changes
