Turbo ?'s
Old Sep 15, 2002 | 01:08 AM
RETed's Avatar
If you use the HKS manifold, it'll work with any T04 series Garrett turbo.&nbsp This includes the "T-Series" turbos from Turbonetics (i.e. T66, T76) you mentioned.
-Ted
Old Sep 15, 2002 | 01:25 AM
AreExSeven's Avatar
Huh?
Refresh?
Old Sep 15, 2002 | 01:35 AM
Scott 89t2's Avatar
SOLD THE RX-7!
Originally posted by chris-reed
now i see it, cool thanks ted So if i buy the turbonetics t66 it will bolt up to the 300 dollar cast manifold with external wastegate with no problems? And what benifits could i recieve with a t66 over a tso4
it'll be worse unless you're making over 600hp or so LOL...
Old Sep 15, 2002 | 01:43 AM
Scott 89t2's Avatar
SOLD THE RX-7!
the t76 would probably hit full boost at around 6000rpm... too big. but from 6000-8000 you would have alot of power at high boost
Old Sep 15, 2002 | 01:50 AM
Scott 89t2's Avatar
SOLD THE RX-7!
you'd probbaly want be running 30+ on the t66... to4 would be fine for 15psi.. heck you could just go with a t04 hybrid and save lots of money and work.
Old Sep 15, 2002 | 02:06 AM
Scott 89t2's Avatar
SOLD THE RX-7!
whatever... how much HP are you looking for? and how much boost? you pick that before the turbo...
Old Sep 15, 2002 | 12:14 PM
Ryde _Or_Die's Avatar
What are your goals? Most HP? You said you don't drag race, so your not worried about 1/4 mile time right? I think the ts04 will work great for most applications overall.
Old Sep 15, 2002 | 12:46 PM
stickgoat's Avatar
AE whore nomore
Yeah...what are your goals? If you're going to do a lot of autocrossing and such, a big *** turbo isn't going to help you out much because it'll take so long to spool.
Big turbos are also a bit impractical for the street, because if you don't start really getting into boost until 5k or higher, you're going to have to remain in your upper RPMs which, again, is impractical on the street.
Old Sep 15, 2002 | 05:32 PM
eViLRotor's Avatar
Brother of the Rotary
KKK Stage 1
Old Sep 18, 2002 | 04:31 PM
RETed's Avatar
You're getting a bit confused.
The SR20 runs a stock T25 Garrett turbo.&nbsp These things make a little over 300hp maxed out.&nbsp No, these will not fit on the HKS 13B cast manifold.
Most of the advice you're getting is right - you need to figure out how much power you want.&nbsp It helps to know how much boost you're looking to make - at 15psi-20psi, there are turbos that will give you 400hp very easily.&nbsp These include the 60-1, T04E 60, and TS04.
Be careful about turbo models - you cannot compare the Garrett T66, T76 versus the Mitsubishi T67, T88 - it DOES look very similar!
-Ted
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
