i've narrowed down the wierd BEEP! now i need your guys Help!!
Old Sep 14, 2002 | 07:56 PM
M.C. Language's Avatar
Exclamation i've narrowed down the wierd BEEP! now i need your guys Help!!
ok guys, i tried a search and didnt get anywhere, so im hoping one of you guys will no what it is... Like many people with 2nd Gen's i have this wierd beep that comes on, but i know it isnt any of my fluids.... while it is beeping, i turn the wheel all the way to eother side and the beeping stops, then after about a miute the beep starts Back Up again, so i have no idea whats going on now... so please guys. help me out!
Old Sep 14, 2002 | 08:34 PM
silverrotor's Avatar
When I swapped out Interiors, from s4>s5, I too had a beep going off. Turns out the steering wheel sensor was dirty. I gave It a wipe and never had the problem again. Take the wheel off and give It a wipesies.
Old Sep 14, 2002 | 08:55 PM
RyosukeTakahashi's Avatar
Are you sure it aint the rev limiter thingy. When I first got my car and I raced another FC on that day I thought that someone kept honking their horn at me! maybe its a crossed wire??
Old Sep 14, 2002 | 09:06 PM
Icemark's Avatar
You didn't search or you would have seen that the power steering computer beeps when it has an error code.... such as the wheel position sensor. I did a quick search for the word "beeping" only in the second gen section and found 78 threads with about half of them with the same problem you describe.
So when you turn your wheel all the way one direction or the other it stops.... it is the power steering computer beeping because of an error in the wheel position sensor. Fix or replace the wheel position sensor.
The beeping and power steering errors are also covered in the owners and shop manuals.
Tylerx7fb
39
May 27, 2019 12:45 PM
Kruel13
24
Sep 16, 2015 09:08 AM
Clacor
Aug 14, 2015 09:17 AM
