what could be causing my secondary injectors to not come on?
Old Sep 13, 2002 | 11:57 PM
jacobcartmill's Avatar
just dont care.
If i am accelerating lightly i can get above 4k rpms easily. if i step on it, my secondaries try to come on and it just bogs my car and no accel... i checked the plugs and even replaced the secondaries with some good used ones. what could be causing this? i miss my boost...
Old Sep 14, 2002 | 12:25 AM
AreExSeven's Avatar
Huh?
The 3800 RPM Hesitation my friend. Do a search for it. Plenty of stuff.
The reason it works when you accelerate slowly is it has plenty of time to think about it. When you go fast it doesn't have the time so it stalls there for a second. If I remember correctly, the main cause is bad electrical grounds. But just do a search
Old Sep 14, 2002 | 12:41 AM
just dont care.
it doesnt just hesitate bro, the bitch stops.
Old Sep 14, 2002 | 01:24 AM
jimmyv13's Avatar
Round&Round not Up&Down
Start with grounding your boost sensor,or ground pin 2C at the ECU. Adding extra chassis to engine and battery to chassis grounds might help, too.
Old Sep 14, 2002 | 04:18 AM
Turbo II FC's Avatar
Total Balance is Key
I have the same problem right now. Ive had this problem for a while. I took everything off and messed with the injector clips on the harness for the injectors and it worked for a while. Then one day it stops working again. So I then buy brand new connectors since the harness was kinda beat up. It did no good. So Im not sure what to think now. Im thinking that the secondaries might be clogged or need to be cleaned but then again someone said they had this problem and replaced the boost sensor and it was running perfect. I really need to fix this **** too.
Old Sep 14, 2002 | 11:24 AM
just dont care.
hmm.. i'll go try replacing my presure sensor.
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
