Haltech premix
Old Jul 24, 2001 | 09:26 PM
94touring's Avatar
premix
What kind of premix are most of you guys running? Any particular brands that may be better than others? Thanks.
Old Jul 24, 2001 | 11:08 PM
booosted's Avatar
I am using Motul 600. It is pretty inexpensive at the local motorcycle shop and it is designed not to smoke either. Try it out and you may like it. Late
Old Jul 26, 2001 | 06:58 PM
risc's Avatar
I've been running pensoil <sp> marine synthetic. Mainly because it is the only synthetic I've found localy in 1 gal containers. It is also the cheapest synthetic I've found at $20 a gal. Every thing else is like 8 bux a quart and they only seem to stock a few quarts.
Does motul come by the gal? About how much is it?
-Dom
Old Jul 26, 2001 | 10:26 PM
tims's Avatar
Motul 800 at 100 to 1
Old Jul 28, 2001 | 11:34 PM
booosted's Avatar
Motul 600 is 10 bucks a quart. How does that pensoil do on smoke.
Old Aug 6, 2001 | 03:14 PM
I'll be using this stuff from Pettit Racing:
FL-PE-PRO1 PROTEK-R FUEL LUBE, 4 OZ.
Formulated to meet the extreme demands of turbocharged rotary engines, Protek-R exceeds all expectations. Protek-R, blended in the fuel, helps protect the delicate apex seals and related components that normally receive insufficient lubrication from the stock oil injection system. Recommended usage is 4 OZ per tank of fuel.
FL-PE-PRO2 PROTEK-R FUEL LUBE, 12 OZ. 4.99
FL-PE-PRO3 PROTEK-R FUEL LUBE, 20 X 4 OZ. 36.00
FL-PE-PRO3 PROTEK-R FUEL LUBE, 1 GAL. 49.00
20B Forum
21
Mar 22, 2022 01:00 PM
Andrew7dg
Aug 6, 2017 01:41 PM
Frox
Oct 22, 2015 04:54 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
