Old 09-10-02, 07:04 PM   #1
Dvst8
Dvst8's Avatar
Help on Alarm installation.
hey guys
I finally purchased a alarm for my car and since im just a backyard installer type of guy, i want to install this alarm myself. So has any one got any links/knowledge so i can start on this installation?...etc...any help would be great.
thanks guys.
Dvst8 is offline   Reply With Quote
Old 09-10-02, 07:12 PM   #2
Icemark
Play Well
Icemark's Avatar
Send a message via AIM to Icemark
year and model FC???
Icemark is offline   Reply With Quote
Old 09-10-02, 07:14 PM   #3
Dvst8
Dvst8's Avatar
its an 86 GXL
Old 09-10-02, 07:51 PM   #4
Icemark
Play Well
Icemark's Avatar
ah your bummed, no factory alarm plug.
I'll post what wires and the best place to find them later tonight.
Old 09-10-02, 09:25 PM   #5
Icemark
Play Well
Icemark's Avatar
Alarm wires for a 86:
Ignition: large gauge Blk/wht @ switch or drivers kick panel
starter kill: large gauge blk/grn @ ignition switch or drivers kick panel.
door trigger: Blu/wht @ CPU
door handle trigger: yel @ CPU
Hood trigger: none on a '86, add hood pin.
trunk trigger: Grn @ hatch locks, and idiot lights
12V+: Large gauge Blk @ ignition switch
Key sense: Blu @ CPU (positive trigger).
parking light + tigger: Red/Blk @ CPU or light switch
Parking light - trigger: LightGreen @ CPU or LtGrn/Org @ hazard switch.
Horn: Grn/Org @ CPU (negitive trigger)
Door locks: Add door lock actuator to each door.
Remote start wires:
Ignition2:
large gauge Blk/Red @ ignition switch
accessory (needed for air conditioning): Large gauge Blue at ignition switch
tach: yel/Blu @ gauges or power steering computer or trailing coil
neutral safety: grn/blk @ ECU
brake (positive trigger): Wht/Grn @ brake switch or CPU or Cruise control computer in drivers kick panel
Old 09-10-02, 09:34 PM   #6
kllntyme
Legend in my Spare Time
kllntyme's Avatar
Send a message via AIM to kllntyme
Is the 87 SE the same?
I have a Viper 800 in need of a new home.
kllntyme is offline   Reply With Quote
Old 09-10-02, 09:45 PM   #7
Icemark
Play Well
Icemark's Avatar
Sort of. The 87 and 88 cars are pre wired for a alarm.
The following can be found at the factory alarm plug on a 87 or 88 FC instead of the locations listed in the earlier post:
Ignition: Blk/wht @ FAP
starter kill: LTGrn/Yel @ FAP or large gauge blk/grn @ ignition switch or drivers kick panel.
door trigger: Blu/wht @ FAP
Hood trigger: Brn/Wht @ FAP
trunk trigger:[/i] DkGrn @ FAP
12V+: Blue/Red @ FAP (7.5 amp draw max)
Key sense: Blu @ FAP
Hazard light flash - trigger: LightGreen @ FAP
Security/Additonal Horn: Blk/Red @ FAP (3 amp positive trigger)
Ground: Black @ FAP
Factory security light: LtGrn/Red @ FAP (500 MA positive trigger)
Old 09-10-02, 09:48 PM   #8
mintrx7
mintrx7's Avatar
Send a message via ICQ to mintrx7
Dvst8 Check your PM, I sent the correct Link to you, hope it helps
If anyone else in interested go to: http://www.atlantarx7.com/secondgenfaqs.html
I found it very helpful and interesting, It not only has alarm installations but a heap of other helpful information
mintrx7 is offline   Reply With Quote
Old 09-10-02, 09:52 PM   #9
Icemark
Play Well
Icemark's Avatar
Those instructions are for a 88 FC, and would not apply to an 86 at all.
In addition there a slight differences in the pin locations between the 87 and 88 models, so use care if using those alarm instructions to match to the wire colors I listed rather than the pins he lists.
Old 10-01-02, 12:40 AM   #10
Dvst8
Dvst8's Avatar
sorry been out for awhile..hmm ..ok so all i have to do is find these wires n cut 1/8inch of plastic on these wires n connect the alarms wires to it right? thanks again for the help icemark
Remote start wires:
Ignition2:
Old 10-01-02, 11:23 AM   #11
KNONFS
B O R I C U A
KNONFS's Avatar
Remote start wires:
Ignition2:
Hey Icemark,
Are you using the Excalibur book? or do you have the DEI CD? or?
I would like to get my hands on one of the DEI CD, any chance you can hook me up? My local distributor en P.R. won't sell them
KNONFS is offline   Reply With Quote
Old 10-01-02, 01:47 PM   #12
Dvst8
Dvst8's Avatar
oh one more question...what is meant by positve trigger and negative trigger..does it mean the pos/neg wires? i just want to make sure im on the right track. thanks
Old 10-01-02, 02:01 PM   #13
KNONFS
B O R I C U A
KNONFS's Avatar
Positive trigger means it will be triggered (or will trigger) by a positive, same concept with the negative.
Old 10-01-02, 03:23 PM   #14
Icemark
Play Well
Icemark's Avatar
Originally posted by KNONFS
Hey Icemark,
Actually, just from the top of my head.
I have the DEI CD's and would be happy to make a copy (I did for one of the others on this board), but the installation diskette is bad, and I need to send it back into DEI to get another.
Old 10-01-02, 06:54 PM   #15
KNONFS
B O R I C U A
KNONFS's Avatar
All of that from the top of your head, WOW you are definetly ahead of me!!
Old 10-01-02, 09:53 PM   #16
Icemark
Play Well
Icemark's Avatar
Nah, I used to work on cars for a living, and I owned a 87 sport that I bought new for almost 10 years before selling it (should have sold the now ex-wife instead at the time when she said we need for me to have car with a back seat).
And I had just put an alarm and remote start in my 88 'vert only about 6 months before this thread was started, so it refreshed my memory.
Old 05-21-03, 12:47 PM   #17
jsotelo
jsotelo's Avatar
Send a message via ICQ to jsotelo Send a message via AIM to jsotelo Send a message via Yahoo to jsotelo
Ground: Black @ FAP
I am putting in my alarm and it's almost done but I don't have a black and white wire at my FAP for the ignition.. I have a 87 base model.. could it be a different color?
Maybe the Black and Yellow?
Also my hood trigger doesn't work.. did cars shipped without alarms have hood triggers?
THANKS!!
jsotelo is offline   Reply With Quote
Old 05-21-03, 12:54 PM   #18
Icemark
Play Well
Icemark's Avatar
Oh this is an old thread.
The hood trigger won't be installed on base models.
At the alarm plug Ignition is Black/Yellow in 87, and key sense is blue (in case you want to use that instead)
Most electrical gremlins actually sit behind the wheel when the car is on the road.
Give a person a fish, they eat for a day. Suggest they search before posting and they learn a skill for a lifetime.
Old 05-21-03, 12:56 PM   #19
jsotelo
jsotelo's Avatar
Yeah it's an old thread but it kicks ass. Without it I would not have been able to instal my alarm.
It's actualy been a lot of fun.. I've never done it before and the door actuators were cool to get working.
Thank you much for everything Icemark!
Oh one last thing.. is the car prewired for a hood sensor? I mean can I just get a pin and tap into the wires somewhere or do I need to run new wires... don't feel like taking the car apart again..
THANKS AGAIN!!
Old 02-05-04, 05:51 PM   #20
sunshine
sunshine's Avatar
I'm gonna go out on a limb here, and bring this one back form the dead.
Icemark - can you post a similar wire/color/location description for S5 models?
Maybe this should be archived?
'87 TII - waiting for an LS1
'06 Mazdaspeed6
'06 Mazda 3s
'03 Mazda Tribute ES-v6 - Sold.
'91 TII Swap - R.I.P.
sunshine is offline   Reply With Quote
Old 02-06-04, 09:47 PM   #21
RETed
No Sleep, No Food
The problem with posting help on alarm installs in such detail is that you give thieves a blueprint of your alarm.  This is why I try to refrain from offering such detailed advice or to have general rules on what wires goes where.  It's easy for a seasoned thief to attack the wires going to the stock alarm, since he knows where this is already.  I usually run my wires in very hard to reach places and keep them hidden as much as possible...
If anything, get a hood lock also.  Since we've been coming across teams of thieves that like to break windows, pull hood latch, and cut the battery cable...in under 2 seconds, and it sounds like your alarm is just chirping.
-Ted
RETed is offline   Reply With Quote
Old 02-06-04, 10:21 PM   #22
sub9lulu
sub9lulu's Avatar
Trader Score: (7)
so glad that someone bring it back
sub9lulu is online now   Reply With Quote
Old 03-09-04, 07:02 PM   #23
sunshine
sunshine's Avatar
trunk trigger:
DkGrn @ FAP
Ground: Black @ FAP
Factory security light: LtGrn/Red @ FAP (500 MA positive trigger) [/b]
Can we get a list like this for an S5 car?
Also..where is the FAP located?
Thanks,
-a
Old 03-09-04, 10:41 PM   #24
Icemark
Play Well
Icemark's Avatar
Thanks,
-a
No Factory Alarm Plug on the S5 models, and all the same wires can be found at the CPU in the drivers kick panel for S5 models.
Old 03-10-04, 12:13 AM   #25
Cybaster
!3BTD-06
Cybaster's Avatar
Send a message via ICQ to Cybaster Send a message via AIM to Cybaster
So installing in a TII should be the same with the diagram described above?
Cybaster is offline   Reply With Quote
HTML code is On
