Differential Install
Old Sep 10, 2002 | 12:14 AM
Digi7ech's Avatar
I break Diff mounts
Talking Differential Install
Well. Saturday I installed my new differential mount.
The total time was about 6-7 hours but that was cause I was watching TV while putting it in.
TV's in the garage rock.
I was bracing for a long haul difficult thing but it was just a little time consuming but easy.
I did it all by myself.
OK I bought some PB Blaster and some jack stands.
I then jacked it up and removed the exhaust Y pipe back. (not that hard)
I then removed the 4 nuts holding on the subframe.
Then removed the subframe link thing bolt.
Then just pulled it down.
When people say you need to drop the subframe down 5-6 inches they're totally right. They're almost impossible to get to with it dropped less than that.
Breaking the nuts loose was the only pain really. Just get some type of penetrating stuff and a good long bar to help break em.
just bolt up the new mountl and put the subframe back up and you set.
If anyones in AZ and needs some tips then PM me.
Old Sep 10, 2002 | 12:23 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
One thing left to do...
You're rear toe is now probably off. So, be sure and get an alignment before to much time goes by.
Old Sep 10, 2002 | 12:35 AM
Digi7ech's Avatar
I break Diff mounts
really? What would have caused it?
Old Sep 10, 2002 | 12:41 AM
HOZZMANRX7's Avatar
Automatic issue
Anytime you mess with the geometry of the suspension, no matter how careful you are, it throws things off.
I just did exactly what you did, only I just removed ONE bolt of the sub-frame as well as the lower center link bolt. Aside from dropping the Y-pipe, it's all you really have to do as then you can tilt it enough to expose the front mount bolts.
I had aligned the car not more than 2 months ago, but had it checked. Sure enough, the toe was off.
Drive well, drive safe.
Old Sep 10, 2002 | 01:02 AM
Digi7ech's Avatar
I break Diff mounts
Well I'm getting some Koni Adjustables put in the front in a week so I'll have em set that when I go.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
kkev.7788
Sep 2, 2015 01:32 PM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
