Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
A/F ratios....what should i be tuning for?
Old Jul 23, 2001 | 12:36 AM
T2's Avatar
T2
hi guys.....
Currently (i got it back from a shop like this)
it will idle at 12.1 when i start to slowly rev (no boost) it will slowly climb up to a high point of 14.7.....and in data logging i have recorded a highest measurement of 15.9
What should i try to keep the A/F at, on cruise, idle, and on WOT.
btw, its a Microtech MT8
s4, stock turbo
Old Jul 23, 2001 | 01:05 AM
HWO's Avatar
HWO
inteligent extratarestril
on boost over 5000, no leaning than 11.5:1, its the stock restricter opps i mean turbo, which is you biggest bottle neck at the moment.
14:1 crusing without idle sounds a tad too lean aswell.
Old Jul 24, 2001 | 03:30 PM
newRX7fan's Avatar
No, that's fine, although he said 14.7, not 14.1. If you have closed loop operation, cruising should be close to 14.7:1 (average, it'll bounce above and below that). If it's open loop it doesn't matter much, but making it richer than 14.7:1 just wastes fuel. You can lean it out up to the point that it begins to misfire, then that's too lean.
Old Jul 24, 2001 | 05:02 PM
T2's Avatar
T2
update...
after data logs i found this out :
On idle its averaging around 12.9-13.5
On cruise its 14.7 (closed loop i guess)
On boost its 12.5-13.0
Im guessing THATS why its blowing black smoke..
Im going to get some new plugs, take it to my tuner d00d guy, actually ill get two sets of plugs =D and we will get it running better....
thankyou for ur help
oh ps, i really need that intercooler, i had a 100 degree celcius intake temp on a big burnout =D
(simulated burnout of course..... )
Old Jul 25, 2001 | 02:30 AM
The_HITman's Avatar
If you are going off the reading of your Microtech I would not trust them for even one second. They are a guesstimation on a non-temp corrected O2 sensor. You should only trust the figures from an accurate and dedicated wide band Air Fuel ratio meter.
Microtech MT-series do not do closed loop, nor is it programmable for closed loop features to select a target voltage from the sensor to aim for under different conditions.
If you run true 12.5 to 13.0:1 under boost at WOT it should not blow smoke and would infact be hours away from needing a rebuild. :-) Being a Microtech you should be aiming for at least 11.5:1 as HWO has said correctly. Idle around 12.6:1 and cruise at 13.8 to 14.5:1
Old Jul 27, 2001 | 02:58 PM
RICE RACING's Avatar
lol.....c'mon MICROtech is one of the world leaders in rotary engine managment systems isn't it ?
I love the screwdriver adjustable series of computers, I think they were on a good thing back then.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
