Blowing oil on T-78
Old Aug 30, 2002 | 09:50 AM
Buckeyeauto's Avatar
Blowing oil on T-78
Hey guys wondering if you can help me out on this one.
I just installed a greddy T78 kit on my car and when I stay into the boost (15psi) and let off ..coast.. then I give it throttle a HUGE plume of smoke comes out of the exhuast. I know it was oil because one of my friends was following me and he said it got all over his car and it smelled like oil too. I can also see my oil pressure guage rise to the top when boost is coming on.
I have searched for this problem and came to the conclusion that:
1. I hooked up my t-78 Kit wrong and the oil pressure is leaking past the turbo seals and misting into the intake system and causing the smoke, or the oil return line on the turbo is kinked or clogged.
2. Another thing I read was that I should have a restrictor in the oil line and that the 13b-REW produces so much oil pressure that it could leak past the turbo seals. But wouldn't Greddy already think of this and include it into the kit?
Any thoughts on this?
Old Aug 30, 2002 | 11:38 AM
Do you guys think its because I'm running a Stock mount intercooler (PFS) with such a big turbo?
Old Aug 30, 2002 | 12:10 PM
nocab72's Avatar
03 Cobra Killer
Buckeyeauto:
"when I stay into the boost (15psi) and let off ..coast.. then I give it throttle a HUGE plume of smoke comes out of the exhuast"
Classic symptoms of not having a restrictor pill in the oil line and using a BB turbo.
K
Old Aug 30, 2002 | 12:28 PM
Kyle, thats what I read when I did the search for this problem. Where is the restrictor pill? Is it in the steel braided line leading to the inlet of the turbo?
Old Aug 30, 2002 | 12:30 PM
Nocab72(Kyle) I dont think that the Greddy T-78 is BB. Is it?
Old Aug 30, 2002 | 01:02 PM
nocab72's Avatar
03 Cobra Killer
buckeyeauto - you know, im's not sure either, but I have two friends here in town both with T78's. The one with the restrictor pill has no smoke after a run, the one w/out a restrictor gets oil smoke.
Hopefully 9000rpm or R-Magic can jump on this thread and answer your where does the restictor pill go question because I'm not sure ... I don't get to go single till next month...
k
Old Aug 30, 2002 | 10:43 PM
zayrx7's Avatar
the mazda zoom zoom store
hey kyle you do know that is brian, don't you.
Old Aug 31, 2002 | 12:08 AM
scott(pittsburgh)'s Avatar
the pill willl go in the rubber line(3/4") coming from the bottom of the turbo.. i don't have a pill in mine and some times it's smokes a lil when i get on it.
Old Aug 31, 2002 | 01:03 AM
nocab72's Avatar
03 Cobra Killer
hahaha, nope I didn't!
K
Old Aug 31, 2002 | 02:13 AM
Silver93T's Avatar
Braap Braap Braap BOOM!
Where can I get a restrictor pill? I have some oil in my intake tract and a bit comes out of my blow off valve. I also get a puff of smoke somtimes after a hard boost run.
Old Aug 31, 2002 | 09:32 AM
Scott, Wouldnt the restrictor pill go into the oil inlet line to the turbo? I thought that the line leading out of the turbo should be big and have no restrictions so the oil would not back up under high pressure. I'm taking my car apart today. If I find anything I'll let everyone know.
Old Aug 31, 2002 | 09:48 AM
Jason's Avatar
The one
I dont have a pill in my line and it seems to run fine. How mant T-78 cars do we have in columbus
Jason
Old Aug 31, 2002 | 02:17 PM
AggieDave's Avatar
What kind of oil pressure are you running? you should not need a restrictor on a T-78 that is not a BB turbo
dave
87 TII (Series V Conversion)
Old Aug 31, 2002 | 03:20 PM
if your blowing oil out the bov and it's in the itake system/ ic pipes, you might have a leaking turbo..i know when i was spitting oil out of the bov's on my 300zx, my turbo's were shot...
Old Sep 2, 2002 | 08:33 PM
Badog's Avatar
Brian, that you? How is the new FMIC and rad? I heard it took you guys a little too long for the install. How is the oil problem?
Old Sep 2, 2002 | 08:34 PM
Badog's Avatar
Jason
Um. Brian, Vila. I thought you were running a 04S, Jason?
Old Sep 2, 2002 | 09:02 PM
Bad dog, the install for the FMIC and the radiator took a long time. There was a big difference when I switched to the front mount over the PFS unit. I was getting on it on Sunday and thought it wasn't that much better then my PFC SMIC. I later found out that night that the coupler on the turbo housing had come off from one of greddys shitty clamps. Reconnected it with some screw type clamps and noticed a big difference. Maybe thats why my car was smoking in the begining. Who knows. I will keep everyone informed on what I found out.
Old Sep 2, 2002 | 09:03 PM
By the way Jason is running a T-78 too.
Old Sep 2, 2002 | 09:12 PM
Silver93T's Avatar
The hose clamps that come with the greddy intercoolers are garbage. I am going to pick up some t-bolt clamps tomorrow.
Old Sep 2, 2002 | 10:11 PM
R-magic's Avatar
See what happens when Xavier works on your car!
Old Sep 2, 2002 | 10:20 PM
Silver93T's Avatar
Xaveir? wtf? lol
Old Sep 3, 2002 | 10:52 AM
R-Magic, didn't Xavier help you out with your install
Old Sep 3, 2002 | 02:52 PM
RX794's Avatar
NYC's Loudest FD
I had a T88 turbo kit(in the middle of installing another kit on my new FD) on my old FD(same install as a T78), and I just installed it the way it came, with nothing else added, and never had this problem, maybe the turbo has an internal problem.
Old Sep 3, 2002 | 03:13 PM
R-magic's Avatar
Xavier knows I'm messing with him! I couldn't resist.
Old Sep 3, 2002 | 03:32 PM
nocab72's Avatar
03 Cobra Killer
Jason
You have to get into boost before it smokes...hahahah
K
