Can't Find Wire For Fan Mod
Old Aug 28, 2002 | 01:50 PM
sam001's Avatar
Angry Can't Find Wire For Fan Mod
tried doing this fan mod over the weekend.
http://www.scuderiaciriani.com/rx7/fan_mod.html
i can't find the module or the wire mentioned on the site. anyone have a picture of it??
thanks
sam
Old Aug 28, 2002 | 01:57 PM
black99's Avatar
Lurking..................
The module is a black box with a little round circle(spade) connector on the end. I thought it had a spade connector on the end, I could be wrong though it's been a while since I looked at it. You did look around where the ecu is and still can't find it? Did you try unbolting the ecu and looking for it? Mine was not hard to find, it's not attached to anything..
Old Aug 28, 2002 | 01:58 PM
blackscorpio's Avatar
#1 F0RUM TROLL
why dont you try the voodoobox fan mod?
Old Aug 28, 2002 | 02:51 PM
sam001's Avatar
yeah i tried removing the ecu too. still couldn't find a black box. found a blue harness with a black/green wire. but i don't think that's the right wire. the site said there are five wires in the harness. the blue one i found has much more than 5.
is the voodoobox one the one that taps into the relays? if so that's the one i ended up doing. but i don't want this one... i want the fans to run after i shut down. and... call me picky but this is just another set of wires that run through the firewall that don't need to be there (if i can get the other fan mod working).
is there a possibility that canadian fd's are different?
Old Aug 28, 2002 | 02:56 PM
Toadman's Avatar
Nomad Mod
Mine cannot be found also. I did find a black wire with a female spade connector coming off the small black box so I tapped into it, ran it to a lighted rocker switch in the console, then from there to ground. I flip the switch and the rocker lights up! WTH? The wire hanging is supposed to be a ground, not hot! I have no idea why a hot lead is hanging from the stock ECU box/loom. Anyways, still cant find the wire. Guess I'll have to unwrap the loom in case it is tucked in there somewhere.
93 5-speed with recalls completed
Old Aug 28, 2002 | 03:01 PM
#1 F0RUM TROLL
sam001- if you have voodoobox fan mod and your fans are on for a couple mins b4 shutdown, they will stay on for 10 mins after the car is off. Just a FYI
Old Aug 28, 2002 | 03:42 PM
YayeR's Avatar
voodoobox fan mod ?
Old Aug 28, 2002 | 03:52 PM
Rated R1's Avatar
Oji San
http://rx7.voodoobox.net/howto/fanswitch/fanswitch.html
Old Aug 28, 2002 | 04:40 PM
sam001's Avatar
ok yeah... the voodoobox fan mod is the one i did. was too lazy to check the site again to see if it was the same one. lol. anyways... i ran mine for about 15 mins straight while i was driving and when i shut down the car and switch the fans turned off. i must have a special version of the fd. haha.
Old Aug 29, 2002 | 08:50 AM
#1 F0RUM TROLL
I think some cars have the fan update performed? that might make the difference.
Old Aug 30, 2002 | 02:53 AM
Flyrx7's Avatar
Money Pit
It is actually a recall modification, and I believe it is still free from the dealers, as long as the car never had it performed. It is just a small wiring harness and black box that is installed between the pre-existing harness. The wire is a shielded female spade connecter. To test, turn the ignition to on (not start) and ground the connector, fans should come on, if not, you have a bad relay or the little black box is fried (happened to me).
Frank
Old Aug 30, 2002 | 08:03 AM
sam001's Avatar
so without the recall performed will the fans turn off when i shut down the car? is that why that's happening with my car? how hard is it to perform the recall mod if i get the parts from mazda? i don't like having others work on the car.
Old Aug 30, 2002 | 11:46 PM
the_saint's Avatar
I haven't seen a Canadian FD with that black box Mine has all the recalls done, but does not have that box either.
Oh well.
Old Aug 30, 2002 | 11:51 PM
puma's Avatar
canadian monster
exactly, canadian fd doesn't have that
streetlegal?
Mar 17, 2022 02:46 PM
The1Sun
Mar 18, 2018 11:08 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
