t88 turbo
Old Aug 27, 2002 | 05:09 PM
floman's Avatar
t88 turbo
Can you fit a T88 turbo in a stock 1993 rx7.
Old Aug 27, 2002 | 06:29 PM
SPEED_NYC's Avatar
RX-Parts
are you related to Carl?
Old Aug 27, 2002 | 06:34 PM
floman's Avatar
no
Old Aug 27, 2002 | 06:57 PM
20B Junkie's Avatar
LOL.
Old Aug 27, 2002 | 06:58 PM
20B Junkie's Avatar
Re: t88 turbo
Yes you can but what do you mean by "stock"?
You'll need a manifold for the turbo, down pipe, etc. Then do fuel upgrades.
Old Aug 28, 2002 | 07:04 AM
floman's Avatar
Do you have to have an ecu or can you drive with stock one in.
Old Aug 28, 2002 | 07:05 AM
floman's Avatar
correction, new ecu instead of the stock one.
Old Aug 28, 2002 | 07:57 AM
will this be for street use? if it is that turbo will be to large
Old Aug 28, 2002 | 04:47 PM
floman's Avatar
yes, why will it be to large.
Old Aug 28, 2002 | 05:42 PM
too much turbo lag. unless you plan on spraying at every stoplight.
Old Aug 28, 2002 | 06:04 PM
if it was for everyday street use I would go with a to4e, you will spool sooner and it will be more fun to drive. the rx7.com car doesn't even use that big of a turbo, you would have to spray just to spool or rev up to 12000.
Old Aug 29, 2002 | 10:42 AM
20B Junkie's Avatar
Floman, what kind of port you going to be running?
20B Junkie's Avatar
Yes, Haltech is good.
Old Aug 31, 2002 | 11:47 AM
VTECthis's Avatar
Apexsealistically Chalngd
niether of you know what you are talking about obviously. With the proper ports, a T-88 will do just fine on the streets with no NOS. And by the way, the T-88 is EXACTLY what the RX7.com car uses, you should look at it sometime and stop reading magazines.
Rob
93 RX
under construction
Turbonetics T-72 BB, haltech.
Old Aug 31, 2002 | 12:29 PM
first learn how to read, then go on rx7.com and go to drag car profile. notice it is a T78 not a T88.
Old Aug 31, 2002 | 01:14 PM
93 R1's Avatar
Rob
93 RX
under construction
Holy ****...Look who's back
Old Aug 31, 2002 | 05:14 PM
VTECthis's Avatar
Pennywise,
First you should stop giving everything you read so much credit. Ive SEEN the car and my freind Demetrios used to be sponsored by them. Second, if you think about it, most of that profile is pure BS. It would be very hard to make that power on a T78, and much easier with a T-88. Ive seen the turbo itself, he took a T-88, put some garret internals in, changed the exhaust housing, and then slaped the T-78 badge on it. Why would he want everyone to know which turbo he has? Its kind of like him saying he runs only ONE RP fuel pump, which doesnt really support that much power. Stop beliveing everything you read.
Rob
Old Aug 31, 2002 | 05:19 PM
al900rr's Avatar
The T88 will fit but you'll have to either bang the crap outta your downpipe or shave your lower intake manifold.
I could've swore RP used a T78 in their race car. I have a T78 and it's laggy already. I would never recommend a T88 for street use unless it was coupled with nitrous. Like someone else mentioned I would go with a TO4E or a Apex IHI for street use. The Apex kit spools just as fast as the stock twins with alittle more high end.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
