Is a boost controller needed when going non-sequential?
Old Aug 27, 2002 | 12:08 PM
Toddzilla's Avatar
Yes, I did a search. I just want to make sure that I can keep the boost down to 10psi when I go non-sequential. Is a boost controller necessary with my mods?
Old Aug 27, 2002 | 01:57 PM
Toddzilla's Avatar
Come on, there are enough people here that are non-sequential that can answer this.
Old Aug 27, 2002 | 02:02 PM
nmo93's Avatar
just went non-seq the other day. max boost i am seeing is 8 psi. still waiting to talk to ryan(don't be a rikki) about turning up the boost. i would think you need a boost controller. even now w/ your seq setup i would think that you are past 10psi. nick
Old Aug 27, 2002 | 02:06 PM
Toddzilla's Avatar
Thanks, right now I see 11psi on the 1st turbo and in the few times I've gotten on it, I've seen spikes of 14psi when the second turbo comes on. I just want good reliable boost so i am just going the way of the poor-man's non-sequential.
Old Aug 27, 2002 | 02:20 PM
black99's Avatar
Lurking..................
I would recommend one. Even if it's the home depot manual boost valve..
Old Aug 27, 2002 | 02:21 PM
black99's Avatar
Opps Rikki got to ya first..
Old Aug 27, 2002 | 02:57 PM
jpandes's Avatar
Boost Control w/ Non-seq
I see a spike to 14 psi and then boost settles down to 12 psi till redline.
With my mods I have to use a boost controller w/ non-seq. Otherwise, I can't control boost at all.
Old Aug 27, 2002 | 03:40 PM
twstd rx's Avatar
Re: Boost Control w/ Non-seq
Would that be considered a spike or is it actually creep?What psi chip is in your M2 stage 3 ECU?
I had a Gforce ECU (I've heard they are all pretty much the same) and the 12 psi chip and the 14psi chip acted pretty much the same. I'd get 14 psi and it would settle back to 12 til redline.
cristoDathird
28
May 30, 2019 08:47 PM
