Oil Cooler Stainless Steel Braided Hose
Old Aug 26, 2002 | 02:58 PM
gonzz's Avatar
Anyone got any on a 80 RX-7? Can i get them made or do i need to order from RB? Anyone have any of these? Let me know which way i should go..
Thanks, Steve
Old Aug 26, 2002 | 03:24 PM
Directfreak's Avatar
I am a Jeeper Now.
Re: Oil Cooler Stainless Steel Braided Hose
Thanks, Steve
Racing Beat's are a Nice fit...
Old Aug 26, 2002 | 03:53 PM
mar3's Avatar
Administrator
PM innitab, I gave him a very detailed run-down on this very subject if you don't want to spend the $$$ for a pre-made set...I tossed my notes on the subject myself...
Old Aug 26, 2002 | 08:09 PM
FD Racer's Avatar
sold the FD...kept the FB
The mazdatrix ones are better. They simply bolt on.
The RB ones look cool but, you have to buy all the adapters to go from regular threads to -AN.
http://www.mazdatrix.com/b6.htm
Old Aug 26, 2002 | 08:30 PM
I am a Jeeper Now.
Yeah, but -10 lines look Sooooo Nice..
BTW, Mazdatrix offers it both ways.
Old Aug 26, 2002 | 09:22 PM
setzep's Avatar
Wow, Alex you got that engine looking good! What did you use to clean it?
Old Aug 26, 2002 | 10:12 PM
Manntis's Avatar
add to cart
isn't that the new one?
Old Aug 26, 2002 | 10:30 PM
WackyRotary's Avatar
standard combustion
You can make your own A/N lines. You need to buy the hose by 5ft increments if I remember, you won't use all of it, but you can reuse the end fittings in the future and put on new lines on and them and be on your way.
Anyway, I bought some line and the fittings I need to make a 2nd gen cooler work on my car. I did some creative aluminum wielding to the cooler fitting to make it a VERY good fit in the location I have it at, anotherwards, its perfect for any '83-85 12a only. Basically the lines coming out of the cooler have elbows wielded in and the top outlet is aimed towards the 1st gen battery and the line is routed in a curve over to the front cover. Some cutting to the radiator mounting is required to get it to not rub on it. The bottom line coming from the cooler has a elbow on it also that goes straight through under the '85 radiator to the rear of the engine.
After this I did a mock up with heater hose and then cut the lines to fit the fittings at correct length. PERFECT! I will have to put pics sometime. I did this in late march.
I forgot what fittings I used, but its pretty easy for a performance shop to find what you would need to make the lines. However the Oval ends used on a 2nd gen cooler may have to be ordered from Mazdatrix if you choose to use them.
Old Aug 26, 2002 | 10:50 PM
I am a Jeeper Now.
Newer - as in 1995 engine - yes. It did not look that way when I got it though. At all.
Brake Cleaner, Carb Cleaner, WD- and little metal polish on paper towels (it's a dispenser).
If you think that came out good, check out the Tranny!
That one had the help of a Pressure Cleaner.. It was downright NASTY when I first got it.
Old Aug 27, 2002 | 12:11 AM
RotorMotorDriver's Avatar
Seven Is Coming
Damn dude, those are some clean parts....
~T.J.
Old Aug 27, 2002 | 12:16 AM
gamble302's Avatar
roadkill hats rock
i wish i had a big garage to work on my car in.
oh well my one car beats the street
Old Aug 27, 2002 | 12:51 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
Hey Steve,
www.sevensonly.com is the shop that built that tube frame 3rd gen and the Pro7 1st gen I showed you at LVMS. They just made me some -10 oil cooler lines, with ready to thread in -10 fittings for the oil cooler, and simple weld in brackets to mount my Rx-4 oil cooler for about $200. -10 is NOT cheap! The oil cooler fittings don't use an adaptor, they just thread right in real nice.
-brad-
