One BAD DAY, Blow Raidator, and drive shaft!
Old Aug 24, 2002 | 11:06 AM
RangerJoeEOD's Avatar
Question One BAD DAY, Blow Raidator, and drive shaft!
I was having this vibration and sound from light up to 40 MPH and than just gets real bad, almost undriveable. so i take it to a gut that does REXs to look at it, when we get back form the test drive, there is a big pool under car, pop the hood and ther is anitfrize spraying out of the top of the raidator housing. and he said not to drive the car the virbtarion was the drive shaft!! does any one ever replave a raidator? Can i do it my self, tying to save some cash!
Old Aug 24, 2002 | 09:50 PM
deadRX7Conv's Avatar
Opinions are like........
You can replace the radiator. Its easy if you have a basic set of tools.
You can download the FSM from iluvmyrx7.com or fc3s.org and buy the haynes book.
If you plan on keeping the car a long time, it would be good to upgrade to a higher quality radiator.
http://absoluteradiator.com/cgi-bin-...fd2+1030244090
But, since you are trying to save money, a cheapo parts store radiator is good enough for an NA. While you're at it, buy a new Mazda thermostat/cap and remember to use the same coolant that the car came with.
Ujoints aren't serviceable. Some driveshaft/axle shops can replace them. May/may not be worth the aggravation to try to replace them yourself. Plus, there are usually some on ebay/salvageyards/partstrader......
Old Aug 25, 2002 | 01:14 PM
Thanks for the info, I think i am sticking with a stock Radiator for now, used i think. I have a shop that will do the drive shaft for 80 bucks. And i found one on ebay. Hope it works out.
Old Aug 25, 2002 | 03:11 PM
Barwick's Avatar
SCCA Rookie
get yourself an aftermarket radiator as long as you're replacing it. All aluminum.. these cars run hot, and you can't go wrong keeping them cool.
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
