t2 tran onto a jc cosmo 13btt??
Old Aug 23, 2002 | 02:48 AM
DJ!
Question t2 tran onto a jc cosmo 13btt??
well i just brought a 1992 jc comso 13b twin turbo engine and i would like to know if the know if the a t2 trans will fit on which i think that it does? and the flywheel can i just use the one off a t2 and would that fit onto the cosmo block with no promblems??
Old Aug 23, 2002 | 04:33 AM
Keaponlaffen's Avatar
Should fit fine, but I think you'll have to swap flywheels and counter weights... someone re-enforce this...
Jeff
Old Aug 23, 2002 | 08:24 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
The T2 trans bolts up just fine, you cant use a stock T2 flywheel, cause it wont balance the entire rotational assy. properly..
You need to remove the flexplate, and retain the stock counterweight, and use a lightened steel flywheel with the stock counterweight and the motor will be properly balanced...Just buy the lightened flywhel for the same year/application that the trans is...
Old Aug 23, 2002 | 08:25 AM
MIKE-P-28's Avatar
Oh and talk to Tim at www.horsepowerinabox.com , hes got about the best prices I have seen on combo flywheels and clutches ...
Old Aug 23, 2002 | 06:44 PM
peejay's Avatar
Old [Sch|F]ool
All Mazda rotaries since '74 have the same bellhousing bolt pattern.
(and it's a 13B-RE not a "13btt")
Old Aug 23, 2002 | 10:47 PM
DJ!
yes i do know that its call a 13b - re, just thinkin of some people out that may of not
