Help with Apexi waste gate and HKS EVC EZ
I finally got the Apexi WG working properly. When I had the wg sent to the cermaic coating place they must have "misplaced" the valve guide if you can beleive it. There was a huge hole where the valve goes through the body and the bellows was doing nothing at all. I was boosting to over 20 psi without even getting on the throttle, thank goodness for the boost guage.
Anyways I have not had time to tune on the dyno but have entered a import Drag Warz event this weekend. The WG seems to be working great now but I am wondering where I should set the set screw on the bottom of the WG. I want a max boost of about 18 PSI, running very rich, with C 16 race fuel. Should I be adjusting the boost with the set screw first, then adjust with the EVC EZ? I just have ran out of time to play with it enough and would rather practice launching. Any quick suggestions?
