Anyone have problems with Yaw timing on a GSL-SE
Old Aug 19, 2002 | 06:13 PM
JIMMY54's Avatar
GSL-SE PRO
I've heard of many of you breaking spark plugs using his setting for 12a's but i wanted to know if the same happens on 13b's? If so, anyone know other good timing settings. I wanted to bump it up a little bit, along with doing the TB mod and maybe porting my intake tommrow.
Thanks
JIMMY
Old Aug 19, 2002 | 08:40 PM
JIMMY54's Avatar
GSL-SE PRO
BUMP
What do you guys with -SE's run for timing if the Yaw is no good?
Old Aug 20, 2002 | 08:05 AM
David88vert's Avatar
r71's daddy
I know several GSL-SE owners that run Yaw's recommended timing with no problems. 26/16
Otherwise, unplug vacuum advance, bump up trailing 5*, and advance your stock timing a little (10-12*).
Stock timing:
L = 5*ATDC
T = 20*ATDC
mechanical advance = 10* for both
vacuum advance = 10* for L, 15* for T
Old Aug 20, 2002 | 02:14 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
Jimmy,
The reason some of us were breaking plugs is likely that our mixtures were not right... our cars were not tuned properly. 'This seems to be the case with a stock Nikki carb and a full header exhaust. Those timing settings are very aggressive, and you had better be sure your a/f is spot on to avoid problems. Also, a bunch of us run the colder platinum FC/FD trailing plugs all around (the 9's). This might help a bit.
Personally I don't like those timing settings; I like about 2 degrees advanced over stock on both leading and trailing, set at idle (vacuum advance is disabled on my car.) But everyone's car is different; to each his own.
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
