Need help, ran 13.6 at Npoi today.
Old Aug 17, 2002 | 08:58 PM
lerch32's Avatar
I am running pettit large, pullies, M2 intake, and PMS set on high for 15psi, and full exhaust. I am thinking it was the silnencer I am running with the N1 that hurt me. I have been using it to help with boost spikes. I think it is really hurting my times. I had taken it out, and was going to try a run, but I was spiking to bad. I am looking for someone who is running full exhaust, with the seq set up, and want to know how they are controling the spikes. I have the PMS set on vent learn, but I think it is to drastic for it to learn.
Old Aug 17, 2002 | 09:00 PM
R Xplicit's Avatar
how's your clutch and overall driving skill?
Old Aug 17, 2002 | 09:02 PM
lerch32's Avatar
I ran consistant all day, and I have a stock clutch, but did not smell like it was slipping. It was my first time on the track, but I had a R/T of .62. My 60 sucks, but I think that is from the exhaust restrction
Old Aug 17, 2002 | 10:00 PM
racer rx's Avatar
I have a ported wastegate to control the spiking a little more. However I get a little boost drop in at Higher
RPM's.
I also have a Borla XR-1 in the mid-pipe.
I plan on adding a Blitz Boost controller. Too keep boost constant til red-line.
Just ran 13.07 @ 113.6 MPH. 2.1 to 2.2 60 fts. 2300 feet above sealevel.
I can get the car to low 12's with Drag radials..
jc.
Old Aug 17, 2002 | 10:05 PM
suprfast's Avatar
i just ran 13.7 with an HKS DP and apeci intake. street tires that have seen better tread, and a crappy 2.2 60ft.
kris
Old Aug 17, 2002 | 10:14 PM
lerch32's Avatar
I am thinking my heavy *** 18's are not helping.
Old Aug 17, 2002 | 10:26 PM
racer rx's Avatar
leerch32
What are your 60 ft.s? What do your 18's weigh?
jc.
Old Aug 17, 2002 | 10:42 PM
lerch32's Avatar
I made three runs. First 60-2.173, second 60-2.309, and third 60-2.452. I don't know how much they weigh, they are konig imagines. I think heat soak was playing a role in the fact that my times were getting worse. I think the temp was around 105.
Old Aug 17, 2002 | 11:31 PM
racer rx's Avatar
The First run seems to be about right... I have heard of really good driver's getting 1.9 60 ft.s. I did a couple years back but on almost bald Dunlops. I usually get around 2.1's. Remember that every 1/10 you shave off your 60 ft. translates to 2/10's off your e/t.
I carry some ice to the track. For the I/C. I think it does help the I/C from getting heat soaked. Just don't spill the ICE, the track officials will get upset.
Also what MPH were you getting?
jc
Old Aug 18, 2002 | 06:13 AM
lerch32's Avatar
MPH 104, 106, and 107.
Old Aug 18, 2002 | 07:26 AM
amp's Avatar
amp
old yella
heat is a factor...
tires and a better 60ft....
Old Aug 18, 2002 | 07:28 AM
lerch32's Avatar
I am on my way right now to see if I better my times. I am getting 15 psi with out the silencer, and no spikes. I spent all night playing with my vent values. Wish me luck.
Old Aug 18, 2002 | 11:08 AM
racer rx's Avatar
May the Force or Boost be with you...
jc
Old Aug 18, 2002 | 05:26 PM
dizastical's Avatar
I am running street tires and my 60ft times are 2.05 and i ran a 12.85@112 . It is very true that for every 10th in your 60ft should lower your 1/4 mile time by 2 10ths . take off the silencer and dont be affraid of spinning off the line . good luck .
Old Aug 18, 2002 | 09:49 PM
lerch32's Avatar
Well ran all day, and again it was hot. Best time was 13.00, and all the rest were 13.1's. I feel it is a good improvment, but I feel the car is should be breaking 12's. I think the heat, and wheels may have hindered me. I ran in the bracket 14. I should have run in the turbo 6 class. I would have beaten at least two supra's. I think I am going to go single this winter. I am thinking to4s, or t78.
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
musker
Oct 1, 2015 05:58 PM
