Question about a turbo(not the car)
Old Aug 17, 2002 | 10:55 AM
supergoat's Avatar
Eggs are like fowl cheese
Question Question about a turbo(not the car)
Ok, when Summer and I got our TurboII we also got a spare turbo with it. The seals seem to be on good shape, but the turbine takes some effort to spin.
When I am able to get it to spin, it takes a lot of effort, but there isn't any grinding, just a lot of resistance. That's the only problem I can see with it. All I know is that it came off the blown engine and sat for a year collecting mold. Other than the turbine not being able to spin freely it's in fine shape.
Is there any hope for this turbo? If I were to rebuild it, would it be any good? Or should I just trash it? The turbine is in great shape, both intake and exhaust. No bends or chips whatsoever in the fins. It's an 89.
Thanks.
Old Aug 17, 2002 | 12:36 PM
CaR 13's Avatar
u can rebuild the turbo
u can even get it upgraded for more power it costed my freind like 500 or so for his t3 turbo to be rebiult and upgraded
Old Aug 17, 2002 | 02:42 PM
Dragon's MOM's Avatar
Put a T3 on your FC and see what happens...you're engine will fall flat on it's face at 5000 rpms.
You should be able to wiggle the front of the turbine up and down slightly. If you have any back and forth movement, then you'll need to replace the thrust collar/bearings.
Spray some WD-40 into the oil inlet/outlet and then try to spin the turbine.
Old Aug 17, 2002 | 04:32 PM
FC Drifter's Avatar
Damaged Little F*cker
if there is a lot of resistance then the bearings are prolly goin out. id suggest getting it rebuilt or replacing it whenever you get a chance.
Old Aug 17, 2002 | 10:08 PM
stickgoat's Avatar
AE whore nomore
Thanks for the replies. Stephen said he'll try the WD-40 thing tomarrow and see what happens but will probably rebuild it himself.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
bb6guy
Aug 12, 2015 03:29 PM
