Parking Brake
Old Aug 16, 2002 | 10:48 AM
Parking Brake
Has anyone ever taken apart the rear brake system. Focus on the Parking Brake Assembly? I need to talk to someone that has done it before.
Ron
Old Aug 16, 2002 | 10:54 AM
dr0x's Avatar
pei > caek
Get a manual for your car... it should answer all your questions, right?
Old Aug 16, 2002 | 10:55 AM
jabbadeznuts's Avatar
Ron,
With rear disc brakes, the parking break assy. simply actuates the rear pistons. If you mean "take apart" as in a pad change, just go about it the same way you do the fronts. However, If you mean a complete rebuild I'm not the guy you need talk to.
7 brake Gurus, this one is for you!
Old Aug 16, 2002 | 10:56 AM
Nothing gets into the assembly itself. All the manuals stop with where the cable attaches to the fork. I need to talk about the internal mechanism. I've checked Chiltons, Haynes, and the official Mazda Manual.
Ron
Old Aug 16, 2002 | 10:58 AM
I need a Guru.
Old Aug 16, 2002 | 11:03 AM
Vroomaster's Avatar
yah, my parking brake sucks and doesn't hold on any kind of hill. If you find out anything, let us know....
Old Aug 16, 2002 | 11:06 AM
Well, I fixed the thing. They get all stuck on one side. The only way to fix it is to tear it all apart and fill it with penetrating oil. I did that and now it locks of just fantastic. The only problem is that the bolt that sticks out of the actuator is loose, it can slide up and down in the sleeve. I don't know what is going on down inside there so I don't know if I have it back together correctly.
Ron
Old Aug 16, 2002 | 11:15 AM
Does anyone know if that bolt should wobble like that?
Old Aug 16, 2002 | 11:19 AM
dr0x's Avatar
pei > caek
I doubt it should... but I have no clue what you're talking about so you should probably ignore me
Old Aug 16, 2002 | 12:02 PM
c'mon
someone has torn apart their sticky brakes before.
Ron
Old Aug 17, 2002 | 10:33 AM
Congrats for havin the ***** to rip it apart. Now you know how it works.
I would imagine that the bolt should NOT stick out.
Did you do both sides?
if not then usethe other as an example.
chiefmg
Sep 10, 2015 07:46 AM
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
