Wacky Electrical Problem
Old Aug 15, 2002 | 08:11 PM
SuperPhly's Avatar
OK, this really sucks, I have to drive 7 hours Saturday and now my radio doesnt work...
I was fooling around with the dome light because it had a small short in it, and like a dumbass I was using a screwdriver and I guess I shorted out the circuit (or part of it) and now none of that stuff up there is getting power. Neither are my speakers, but my EQ, Radio and Tape Deck are. The seatbelt logicon does come on but only for a 1/2 second. The door buzzer doesn't ring anymore (which I kinda like), and the spiffy quartz powered clock doesn't show anything.
However, when I drive I can see 1:00 shown in the LCD, but very very lightly. It will only show when he radio isn't getting power...
I checked the fuses, and when I changed fuses I saw a little spark... so I assume it's a good fuse.
Anywhere else to look? I hope to god I don't have to start pulling wires.
84 GSL Auto
Old Aug 15, 2002 | 09:11 PM
Manntis's Avatar
add to cart
you probably blew a fuse. I did when I was attempting to fix the original light console overhead.
Old Aug 15, 2002 | 11:30 PM
jacobcartmill's Avatar
just dont care.
That little light assembly is the easiest way to shut down the radio and lights in any car... we used to do it to my friends taurus just for laughs....
Old Aug 16, 2002 | 12:26 AM
Manntis's Avatar
add to cart
I bet he thinks har-dee-frikkin'-har when you do it, too *L*
Old Aug 16, 2002 | 12:34 AM
RotorMotorDriver's Avatar
Seven Is Coming
I noticed that my clock LCD did that when I had my stereo out and I was messing with ****...I have no idea why...It was kinda weird. Id say, just check ALL your fuses, and make sure your wires are firmly attached to whatever they go to.
~T.J.
Old Aug 16, 2002 | 01:06 AM
Manntis's Avatar
add to cart
could be you bumped a wire when putting your stereo in and knocked a contact loose, and your speaker wires are similarely poorpy connected.
or it could be a fuse.
Old Aug 16, 2002 | 01:08 AM
SuperPhly's Avatar
I don't think it's the fuses... I check them. The radio works. It comes on and stuff... but he speakers have NADA.
Old Aug 16, 2002 | 01:10 AM
Manntis's Avatar
add to cart
triple check the wiring. we get signal? main screen turn on?
Old Aug 16, 2002 | 01:11 AM
SuperPhly's Avatar
I looked at the wiring diagram... can't use deductive reasoning to figure out why it's borked.
I am going to triple check that damn overhead lighting deal... maybe whip out the damn voltometer...
Old Aug 16, 2002 | 01:12 AM
SuperPhly's Avatar
Yea, friggin finds stations, and stuff... eq powers on and off... everything looks like all systems go... except for the sound. NADA
Old Feb 27, 2003 | 09:39 PM
Black Echo's Avatar
Newbie
This is the problem I'm having now. Car is a 1985 RX-7 GSL, 5 speed 12A, bone stock. I've checked the fuses, they're all good.
Here's my problems and if anyone can help me, I'd appreciate it.
1) Overhead lights do not come on at all, door or dome.
2) Stereo works fine, but won't hold memory for stations. When you turn stereo on, radio or tape player starts to work, antenna goes up, but no sound. I've checked all the connections I can, and everything is fine.
3) LCD clock in dash is blank.
All lights work, dash lights up, just no overhead light, no clock, and no sound.
The engine sounds fantastic, but I really would like to listen to some tuneage sometimes.
Old Feb 27, 2003 | 10:10 PM
Pele's Avatar
Right near Malloy
It's gotta be either the ROOM or HAZZARD fuse... I forget which one will do it, but Here's why.
The clock, interior light, and memory backup on your radio are all run with the key in the OFF position. Ditto with the beep that says your door is open.
MOST aftermarket stereos also power their internal amplifiers off the memory backup circuit. Hence No cound or stored stations, but the radio will still appear to come on.
All problems point there.
The faint 1:00 on the clock is due to power getting through something else in the system and powering up the clock... Remember science class kiddies, you can power a digital clock with a penny and a paperclip shoved in a potato.
Old Feb 28, 2003 | 01:04 AM
FD-less's Avatar
I posted a little while back with a short in the same circuit. Unfortunately, it was like that when I got the car so I have NO luck at all in finding a good place to start. I removed the cigarette lighter, glove box, both bins, both door swithces and the overhead in an attempt to root out the short. It still did it, though the reminder chime, key illumination light and clock memory were still in there. FWIW, my antenna doesn't try to go up and the radio doesn't work on mine now, either. Someone share your common shorts so we might find ours.
Old Feb 28, 2003 | 06:29 AM
85RX7GS's Avatar
Back when I was installing my stereo, I could open and close the door to reset the LCD clock! Not good.
So I pulled everything back out and checked the wiring. I soon found out that I forgot to re-connect the main ground that the dome light, doors and clock work off of. After reconnecting that wire (located behind the stereo surround down near the carpet) everything worked great.
Old Feb 28, 2003 | 06:32 AM
Maguire's Avatar
Born 2 Brap
Black Echo: its sounds like your hazard fuse is blown.
Old Feb 28, 2003 | 10:57 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
How are you ascertaining that the fuses are good? You can't rely on a visual examination as fuses frequently open up under the little metal end caps where you can't see the break. I recently blew a fuse that opened up right in the middle, but the break was so small as to be practically invisible. I could only see the hairline fracture with a magnifying glass. The surest way to test fuses is with an Ohmmeter, or you could use a voltmeter and check that voltage is present at both ends of the fuse.
Old Feb 28, 2003 | 11:16 AM
Manntis's Avatar
add to cart
or just plug in a spare fuse of appropriate amp and see if the problems go away. If so, toss the previous fuse.
Old Feb 28, 2003 | 07:10 PM
FD-less's Avatar
My circuit blows the fuse the instant it touches with the ignition being off. Somewhere between the load side of the fuse and one of the components I'm touching ground and don't know where to start. I've never chased one of these shorts like this - any tips?
Old Mar 10, 2003 | 04:19 PM
smile444's Avatar
I am dealing with a short issue now, I will let you know if I learn anything
Old Mar 10, 2003 | 06:44 PM
s2rx7's Avatar
check fuses with a multimeter just to be sure, check that the battery is charged and can start the motor.
Old Apr 6, 2003 | 04:26 AM
eddierx7's Avatar
i have got almost same problem ,clock resets every time i shut the car off,doom lights dont come on ,and today door and hatch light comes on but some time every thing works, i'm pulling the circut behind clock and my ecu to re sotter them i'll post tomorrow if things get any better
Old Apr 7, 2003 | 08:57 PM
Rex4Life's Avatar
RX-7 Alumni
Recheck your fuse make sure it just didn't re-blow, if it did then you have a short somewhere. Then check the eye terminal ground that should have been attached to the dome light assembly that screws into the roof.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
