Need 280rwhp out of a NA 12a, will a properly setup PP supply this?
Old Aug 15, 2002 | 07:02 AM
Hans's Avatar
as title says can i squeeze 280rwhp out of a properly setup PP 12a
and
Is it possible with a carb?
BTW could care less about streetabiliy of this setup, it is a bet i have with a buddy of mine. he says theres no way 280rwhp outa a 1.1 liter NA
Old Aug 15, 2002 | 07:04 AM
Node's Avatar
I'm not sure about 12a pports, or 12a's for that matter, but you could get 280hp at the flywheel probably
Old Aug 15, 2002 | 09:03 AM
peejay's Avatar
Old [Sch|F]ool
It's possible, but not with a carb.
The early '80s GTU teams were making about 280hp with fuel injection and Mazda peripeheral port rotor housings. When they were forced to switch to a carb, they lost power but got back up to 280hp by altering the port window to a square shape instead of a D-shape, which also made the powerband narrower.
Perhaps you should be more pwrried about the area under the curve instead of a single peak HP figure. 99% of the time, the engine is not running at peak HP, it's above it or below it.
Old Aug 15, 2002 | 09:39 AM
Node's Avatar
PJ, where do you learn these fun facts?
Old Aug 15, 2002 | 04:22 PM
peejay's Avatar
Old [Sch|F]ool
Got my methods.
Old Aug 18, 2002 | 10:45 PM
851stgen12a's Avatar
Off riding sportbikes!
I havea a Buddy Here in portland, who has a rx-3 PP 12a. sais dynoed it at 325 at the flywheel.
He also has about 15 g's into his motor.
But 280 hourse is possible.
Old Aug 18, 2002 | 11:29 PM
94touring's Avatar
Talk to Brian at Rotorsports Racing here in NC. He has been contracted to build 12a race engines......price range I believe was something crazy like 20k per engine. http://www.rotorsportsracing.com/
windom
Sep 11, 2015 04:48 AM
mulcryant
Sep 9, 2015 05:24 PM
