Caked on carbon.. how do I get this crap off?
Old Aug 14, 2002 | 05:25 PM
88 SE's Avatar
Im trying to get the excessive carbon buildup on my rotors off to no avail.
Is there any relativly easy way to do it?
Old Aug 14, 2002 | 05:37 PM
88 SE's Avatar
I have the engine apart and am cleaning the rotors is what I mean.
I want them bronze again before I put them back in, not black :P
Atf doesnt do much, surprisingly.
Old Aug 14, 2002 | 05:55 PM
Cheers!'s Avatar
Former Rx7 *****
my what i know... brake cleaner cleans everything and anything...
(if this screws up your rotors/parts) i never mentioned brake cleaner.
So take all advice with a grain of salt, unless RETED or scott89T2 or banzaitoyota chims in ... and scathcart, NZ convert, or hailers.
Old Aug 14, 2002 | 06:03 PM
HN's Avatar
HN
buy 2 gallons of parts cleaner and leave the rotors in for 2 days in a bucket.
Old Aug 14, 2002 | 06:57 PM
Rotorific's Avatar
I dont know a damn thing
i would go with a parts cleaner and soak if your just wanting to display your rotors engine degreaser always does the job in 2 seconds
Old Aug 14, 2002 | 07:28 PM
88 SE's Avatar
Thats just the thing. Ive soaked one of the rotors for 2 weeks + tried engine degreaser and a brass brush.. still wont come off!
Im running out of ideas
Old Aug 14, 2002 | 08:10 PM
rxseven's Avatar
Special Dark
88SE,
You need to get a fine wire brush wheel attachment for your drill and use it to remove the caked on crap. Brass will work but I used a steel one. Do it only where the carbon is and keep spraying carb cleaner while you are at it. Took me just 10 min each after I had already soaked it in paint thinner.
Old Aug 14, 2002 | 09:25 PM
mr. ut's Avatar
lacquer thinneer is metal's best friend
~ut
Old Aug 14, 2002 | 09:46 PM
hypntyz7's Avatar
Yeah, I do this weekly, and I use a wire brush on a die grinder to clean all the engine parts/mating surfaces. I claen the face and sides of the rotors down to bare metal again, then clean the matic surfaces on each rotor housing adn iron plate, after I have already cleaned and painted the external surfaces. For this cleanup, I use aircraft remover/stripper, let it soak for 10 minutes, then pressure wash it off, this cleans the irons and housings up really nice, gets them ready for paint. Then I use the wire brush to remove any paint overspray and the buildup on the mating surfaces.
IF you dont have a high rpm wire brush your not going to get anywhere.
Old Aug 15, 2002 | 12:58 AM
88 SE's Avatar
Just curious ..
I have another rotor that i tried to clean out of another engine and after brushing maybe a bit too hard it started to turn silver instead of bronze .. is that normal or bad?
Old Aug 15, 2002 | 01:01 AM
hypntyz7's Avatar
Normal, it wont hurt anything, in my experience, I have built over 20 engines now.
Old Aug 15, 2002 | 01:04 AM
88 SE's Avatar
What's with the bronze anyway.. some kind of coating?
Old Aug 15, 2002 | 01:07 AM
hypntyz7's Avatar
I guess so,. they did some odd stuff. I was told that they used to be coated with teflon as well, but I can find no evidence of this on any used rotors I have, which exceeds about 50. either a) this is bullshit, or b) it has burned off or worn off, much liek the bronze coating may have.
I think the bronze youre referring to is actually just discoloration from heat cycling and engine duty for thousands of miles. I believe, when they are new, they are silver/gray, though I have never gotten any new ones.
in any case, get them as clean as you possibly can. spare no cleaner or method. Clean out all the grooves and lubricate everything during reassembly, make it move nice adn freely, and youll have a good strong engine. keep it CLEAN!
Old Aug 15, 2002 | 01:25 AM
88 SE's Avatar
Sweet. Ill have to try the high speed wire brush.
I about had a heartattack when my rotor started turning silver, thought I killed it
I just always thought they were bronze cuz pictures I see they always are. I thought the things were brass until one of my spares started to rust
Old Aug 15, 2002 | 01:28 AM
hypntyz7's Avatar
nah just plain old shitty looking, youre not gonna hurt them, but be CAREFUL in handling them, they are SOFT as brass on teh edges where apex adn corner seals go.
Old Aug 15, 2002 | 01:32 AM
88 SE's Avatar
What about this crap the manual says about "bieng careful not to damage the soft coating on the side surfaces" ... is it safe to grind away at the whole rotor?
Old Aug 15, 2002 | 01:34 AM
hypntyz7's Avatar
yup. teh soft coating the FSM talks about is either a) carbon, or b) the teflon earlier mentioned which is nowhere to be found now.
Old Aug 15, 2002 | 02:24 PM
RETed's Avatar
We use carb cleaner *in the gallon can*, not the stuff in the spray can.&nbsp Someone mentioned "parts cleaner", and that should be the same stuff.&nbsp Be VERY careful with this stuff, as it'll eat your skin!
We normally dump the rotors overnight in a small can filled with this stuff, the carbon literally falls off by the next day.
-Ted
Logan Reinisch
44
Sep 17, 2018 12:20 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
younG_Gunner
Sep 9, 2015 08:26 PM
