How hard is it to remove....
Old Aug 14, 2002 | 11:08 AM
How hard is it to remove a Turbo and manifold from a 1990 Rx7 turbo.
I was wondering if I could save myself some money by doing it myself but if its to difficult ill just bring it to a shop.
Thanks
Joe
Old Aug 14, 2002 | 12:43 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Not to hard.. my friend SLOWT2 says its actualy harder to remove the heatshild than to do anything else
Old Aug 14, 2002 | 01:14 PM
Any one know what tools ill need?
and a guess on how long it will take?
Old Aug 14, 2002 | 01:59 PM
FC Drifter's Avatar
Damaged Little F*cker
a few hours i think. yes the heatshield is the hardest part. i just cut mine off with a dremel. im not sure what sockets youll need. prolly just a good metric socket set.
Old Aug 14, 2002 | 02:36 PM
Aaron Cake's Avatar
Engine, Not Motor
Get a Haynes manual.
You'll need a standard socket set with metric sockets. LOTS of WD-40, and perhaps new gaskets for installation.
Old Aug 14, 2002 | 02:39 PM
Cheers!'s Avatar
Former Rx7 *****
gecko7 if u need help.. give me a shout... i have never done nor do i have an idea how to do it... but hte FSM is god and i'm sure 2 people with an FSM and a telephone will figure it out.
Old Aug 14, 2002 | 02:44 PM
Ryde _Or_Die's Avatar
When I installed my DP the hardest part was getting to the bolts. I also sprayed some liquid wrench stuff on for like a half hour and it helped alot.
Old Aug 14, 2002 | 08:42 PM
Thanks for all the replies
Cheers Ill definetly give you a call man Thanks.
Old Aug 14, 2002 | 08:51 PM
Cheers!'s Avatar
Former Rx7 *****
gecko... did i mention there is a time limit to my offer... i'm heading back to kingston for 8 months for school again... so u have to let me know before august is over
Old Aug 14, 2002 | 09:11 PM
mr. ut's Avatar
i beleive u will need a 14mm socket...its tough if u still have the heat shield on, as everyone else has said. the bottom one, i used a wrench to get that off. the two top one, i used the rachet with a 2 inch extension. it also helps if u have small hands...(one of those times when u wished u had girly hands..kekekek).
good luck, ut
ls1swap
Jun 3, 2024 03:25 PM
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Robrods64
Oct 2, 2015 07:56 PM
Rotafuzz
Sep 30, 2015 09:55 AM
