damn coolant light!!
Old Aug 14, 2002 | 08:41 AM
the add collent light comes on at random....got plenty of coolent cant see the problem.....any ideas?
thanks in advance
jeff
Old Aug 14, 2002 | 08:43 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
doesnt it come on when it looses its ground? maby a faulty wire? is the connection loose?
Old Aug 14, 2002 | 08:47 AM
The Ace's Avatar
Greek Power
"Plenty of coolant" doesnt cut it actually....you have to have at least the necessary amount of coolant, otherwise the little sensor gets un-grounded, and you get the annoying buzzer and light
IF you dont have any problems with your cooling system, and the sensor/wiring is correct, then its probably some air bubble in the cooling system. Bleed it/burp it, and you'll be set...
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
rx7shirley
Sep 2, 2015 02:11 PM
