Weird Idle Problems
Old Aug 14, 2002 | 03:47 AM
Sean_O's Avatar
Question Weird Idle Problems
Hey guys, I've got yet another question about my '86 N/A RX-7.
Recently I've been experiencing soem weird idling problems. Some times I''ll start it up and it will idle fine (at ~750 rpms), other times it will idle at 500rpms or lover. Sometimes dropping to the very bottom bar, and often times it just stalls out.
Today I picked it up from the shop and initially it ran fine, idled at 750. But every time after that today that I took it out, it idled at 500 or below, often fluxuating between about 100 and 500rpms. It also stalled out on me about four or five times, which makes driving downtown incredibly annoying as I have to keep the throttle slightly depressed so that it doesn't die.
Anyways, anyoen have any suggestions abotu what this could be from? I have an HKS intake and I'm wondering if maybe that has something to do with it?
Thanks in advance,
Sean
Old Aug 14, 2002 | 03:55 AM
The Ace's Avatar
Greek Power
Ummmm, nasty intake leak (check your intake elbow), or badly adjusted idle speed ? Could be either....
Old Aug 14, 2002 | 06:18 AM
Sean_O's Avatar
How would I adjust the intake speed?
Old Aug 14, 2002 | 06:20 AM
The Ace's Avatar
Greek Power
Ummmm, I said "idle speed"
Check your intake for any cracks, and try to hear (with a stethoscope) for any hissing sounds (which would indicate a leak).
Set your idle speed (use the FSM). Also check your BAC (could be bad or needing a good cleaning)
Old Aug 14, 2002 | 11:26 PM
Yeah my 87 Turbo II has been doing the same thing lately...my friend suggested that new spark plugs would be a good idea cuz his rx-7 would do the same thing. He said it makes a world of difference. Dunno if you've already done this but it's worth a try.
Old Aug 16, 2002 | 01:59 AM
Gr8ful's Avatar
Got my ECU wet (vert top drain plugged and I drove with 3 inches of water on the passanger floor) and had very similar symptoms. Changed ECU's and problem disappeared.
Old Aug 16, 2002 | 06:13 AM
Sean_O's Avatar
Thanks for the responses. I haven't been able to find any leaks any leaks in the intake like Ace suggested, so I'll give the spark plug replacement idea a try.
If worse comes to worse I guess I'll take it into dealership and have them look at it, although I'm running out of time before I leave for college.
Ugh, and my drive shaft is going too. The price we pay for a sports car.
Old Aug 18, 2002 | 06:35 AM
Don't I know it! I juss bought my turbo II for $6,000 and I already have to replace the exhaust! But it makes me happy cuz now I get to spend more money on something I actually need and is going to make my car go alot faster
Old Aug 18, 2002 | 10:36 AM
HAILERS's Avatar
HAILERS
Take a look at your BAC electrical plug. Look to see if one of the two sockets is *pushed back* in the harness plug. It sounds like you have intermittant contact in that plug or the harness. Any self respecting bac will maintain a idle close to 750 rpm.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
rx7shirley
Sep 2, 2015 02:11 PM
