big vacuum leak
Old Aug 13, 2002 | 04:47 PM
jacobcartmill's Avatar
just dont care.
big vacuum leak
we finally got my turbo replaced and everything put back together. now when i start my car, it seems that i have a big vacuum leak because the car wont hold an idle. we tried adjusting the TPS and the BAC, but the problem seems to be happening before those systems even get a chance to help it. could anyone show me a picture of the vacuum hoses on the backside of the engine? if not is there anywhere that we can find a diagram of the vacuum system?
i like to 69 girls
Old Aug 13, 2002 | 04:49 PM
tIIforever's Avatar
terminally boosted
is your tid cracked?
Old Aug 13, 2002 | 08:14 PM
just dont care.
no, the TID is fine.
Old Aug 13, 2002 | 09:06 PM
niner's Avatar
will yours rev up at all you hit the gas? i think i might have intake leaks too, mine wont hold idle and will not rev past ~1000rpms. i dont get it though b/c i removed most vacuum stuff and was very carefull putting it together.
anyways... vac diagram is in factory manual and i think haynes too. factory manual is at fc3s.org
or you could try using propane to find vacuum leaks...
Old Aug 13, 2002 | 09:21 PM
pip's Avatar
pip
the blackest incarnation
You have an atmospheric BOV? If so your valve is set to loose, if not keep on keepin on!
Old Aug 13, 2002 | 09:30 PM
just dont care.
nope, i got a oneway valve for the bov so i could vent it. so nix that problem. any other suggestions?
Old Aug 13, 2002 | 11:53 PM
adamlewis's Avatar
Back from teh deadly!
So you dont know for sure if its a vacuum leak?
Also check your PM's!
Old Aug 13, 2002 | 11:58 PM
just dont care.
no i'm not sure if its a vacuum leak... but i thought that would be the source of my major idle problem. what else could it be?
Old Aug 14, 2002 | 12:01 AM
adamlewis's Avatar
Well if youre sure you checked the TPS and BAC correctly...I dunno. Ive got a copy of the 89-91 T2 FSM on CD. If you want to meet somewhere, its yours.
Old Aug 14, 2002 | 12:08 AM
Felix Wankel's Avatar
Super Newbie
Make sure the intercooler hoses are tight.
Old Aug 14, 2002 | 12:11 AM
adamlewis's Avatar
lol yeah...those will kill a car dead in its tracks. I had a friends IC pipe pop off on his miata while he was on the AUto-X course.
Old Aug 16, 2002 | 03:14 PM
just dont care.
yeah i had my intercooler hose pop off cause it wasnt tightened down enough. loudest ******* pop ever... i thought i blew my engine. i **** my pants and got out of the car. luckily it was just the hose and not an apex seal.
alexdimen
20
Oct 23, 2015 01:50 PM
t-von
Sep 10, 2015 01:56 PM
gabescanlon
Sep 5, 2015 12:04 AM
