backfiring
Old Aug 13, 2002 | 08:17 AM
dubulup's Avatar
development
Question backfiring
I test drove a '95 with a few performance mods.
the performance CPU was not hooked up and the car backfired a couple of times. I was wondering what causes this and if it's normal. The car has 45k miles and isn't driven on a normal basis. Will the performance CPU help this condition.
Old Aug 13, 2002 | 09:31 AM
Mahjik's Avatar
Mr. Links
If the pre-cat has been removed, you'll notice some backfiring. Shouldn't be too excessive though.
Old Aug 13, 2002 | 09:35 AM
Swamp RX-7's Avatar
The performance CPU will make it worse. Backfire is unburned fuel in the exhaust. Because the rotary can be destroyed if detonation occurs, the stock ECU dumps a lot of fuel into the motor, and sometimes all the fuel is not consumed, thus causing the backfiring. Thats why our little 1.3L motors need a 20 gal. gas tank. Also, if the timing has been retarded too much, it can cause backfire. However that is unlikely because the timing is electronicly controlled by the ECU, unless you have the Power FC, then you can adjust the timing.
Old Aug 13, 2002 | 09:37 AM
dubulup's Avatar
development
Thanks guys...is there anyway to reduce it?
Old Aug 13, 2002 | 09:45 AM
Mahjik's Avatar
Mr. Links
It depends on the aftermarket ECU that is being used. As Swamp RX-7 mentioned, if there is a reprogrammable ECU, there are a few steps than can be done to reduce it... Usually, it's not worth the hassle.
Old Aug 13, 2002 | 03:49 PM
MazdaMike's Avatar
how bad is it for ur exaust system when ur car backfires.
backfiring, u see a mini explosion outta the exhaust right. like a blast almost. if thats right then i dont know i think its kinda cool. heh maybe thats just the initial d fan in me.
Old Aug 13, 2002 | 04:11 PM
7-sins's Avatar
thats not paint....
Backfiring can shoot out some nasty flames. With the PFC just turn the Fuel Decel up.
Old Aug 22, 2002 | 11:11 AM
dubulup's Avatar
development
still
Old Aug 22, 2002 | 11:34 AM
Mahjik's Avatar
Mr. Links
still
Still what?
If you are going to post *****, at least post something useful...
Old Aug 22, 2002 | 11:44 AM
dubulup's Avatar
development
I quit
Old Aug 22, 2002 | 12:25 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Originally posted by Dont_Be_A_Rikki
HUH?
That's what I was thinking...
Jmpabon93
Sep 30, 2015 04:57 PM
ChanBagz
Sep 17, 2015 03:36 PM
Machupicchu
Aug 15, 2015 05:57 PM
SpeedRacer
Oct 22, 2001 10:13 PM
medphoto
Oct 22, 2001 02:56 AM
