oil change?
Old Aug 13, 2002 | 03:57 AM
faisalk's Avatar
oil change?
After how many miles should one change the oil? my car seems to go 2000 miles before the light comes on. is it normal or seems to be a problem?>
Old Aug 13, 2002 | 04:11 AM
black99's Avatar
Lurking..................
How long to go before changing it? 2500 miles or less
How long to go before adding more?? I think it's 1 qt per 1000-1500 miles because of the turbos consuming oil, could be wrong though.
What light comes on? The "OIL" dummy light or the light that's on the oil pressure gauge?
Old Aug 13, 2002 | 04:22 AM
faisalk's Avatar
The red light on oil pressure gauge comes on
Old Aug 13, 2002 | 04:24 AM
black99's Avatar
It could be your oil pressure sending unit. They've been known to go bad.
Old Aug 13, 2002 | 05:55 AM
skunks's Avatar
I'm a CF and poop smith
the light should not come on!
Old Aug 13, 2002 | 06:01 AM
faisalk's Avatar
The light does not come on when i change the oil. it only comes on after 1500-2500 miles after changing the oil
Old Aug 13, 2002 | 06:18 AM
ninetyfourfd3s's Avatar
Newbie
It's a good idea to check your oil often. Every day wouldn't be a bad idea...
Old Aug 13, 2002 | 06:23 AM
jspecracer7's Avatar
1JZ powered
Originally posted by Dont_Be_A_Rikki
If that light comes on you are in bad shape Please check into this. I would check your oil to begin with and let us know.
-Rikki
yeah...that's BAD that your oil pressure light comes on. Do you have an aftermarket oil pressure gauge?
Old Aug 13, 2002 | 06:26 AM
faisalk's Avatar
No what im worried about is that my apex seals have leaked. I mean is 2000 miles enough for oil to drop low or is there a leak somewhere
Old Aug 13, 2002 | 06:36 AM
1JZ powered
umm...If your "apex seals" leak, then you have a blown engine. No questions asked...
Old Aug 13, 2002 | 06:58 AM
The DJ's Avatar
Does your car smoke in any way?
Old Aug 13, 2002 | 07:02 AM
faisalk's Avatar
Ya my car emits some urburned fuel and black smoke
Old Aug 13, 2002 | 07:05 AM
1JZ powered
How does your car start? Does it sputter on or does it start automatically? Also, do you have an aftermarket boost gauge? The needle should be steady. If it wiggles, then you may have a blown engine...but I don't think you do.
Old Aug 13, 2002 | 07:08 AM
blackscorpio's Avatar
#1 F0RUM TROLL
These cars consume oil(injects oil into the combustion chhamber). If you are waiting for the light to come on to check your oil you are ruining your engine. Check the oil often an fill add more when needed.
LunchboxSA22
37
Oct 26, 2015 10:53 AM
ncds_fc
Aug 15, 2015 10:06 AM
