Air pump removal
Old Aug 9, 2002 | 01:27 PM
95R2-89TII Ground Zero's Avatar
Banned
Air pump removal
As the FC project plugs along....I was wondering what I need to do to remove the air pump. What needs to be taken care of in order to do so. Thank you in advance.
Old Aug 9, 2002 | 02:17 PM
DC350's Avatar
Rotor Head
umm, not 100% sure here. But i think you just unbolt it, take off the belt. And take out the loose wires. IF nothing is connecting to the exhaust cats. And the vacuum line is connected to the race pipe, i dont know what else to state, i'm kinda wondering too. Because i need to take it off too
Old Aug 9, 2002 | 02:18 PM
RestoTII's Avatar
removing the air pump is a simple thing. Just unblot and take it off. From your other posts and all, I'm assuming you can get the air pump out. Then all you need to do it block off all the new leaks (pretty simple with plugs or caps). You'll probably want to get a dual sheave pulley for the alternator. That way you can run another belt (mine's 31.5" if that helps you later) to the water pump. Without the second belt on the water pump, it may slip at higher RPMs, which is never a good thing
Old Aug 12, 2002 | 03:50 PM
Banned
I meant, did I need to port....or will the TII be fine. I've heard rumors that you don't have to have it ported to remove the air pump. Does anyone know if it's true.
Old Aug 12, 2002 | 03:55 PM
pip's Avatar
pip
the blackest incarnation
The air pump has nothing to do with porting your engine...
Old Aug 12, 2002 | 04:29 PM
DaleClark's Avatar
RX-7 Bad Ass
Best path to remove the air pump is to simply unbolt and huck that sucker, then remove the air control valve and install a block-off plate where it was. You have to have NO cats to do this, BTW.
You can run just one belt for the alternator/water pump, but you really need to use a quality Dayco belt or the like - cheap belts WILL slip. Long-term, you do need a dual-belt pulley and two belts - if one of the belts break, you lose your water pump and alternator, which is Way Bad. Redundancy here is good.
The air pump doesn't affect how the car runs at all - it does help with some afterburn and backfiring, but that's the fun part .
Dale
Old Aug 13, 2002 | 01:35 PM
Banned
Thanks guys.
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
