HELP HELP HELP....air flow sensor
Old Aug 4, 2002 | 09:14 PM
BEDAN_00's Avatar
tried to put in a cone filter and saw the electrical for the air flow sensor, so i didn't want to screw around with the wiring. So I put everything back and now i got problems with my car. I start it and it runs for about 30 seconds befor dieing. anyone have an idea about what happened ????????????
Old Aug 4, 2002 | 09:20 PM
BEDAN_00's Avatar
i don't think so.... but i could be wrong.... what would happen with the wires ?????
Old Aug 4, 2002 | 09:29 PM
Rotarius's Avatar
When you install a cone filter there should be no need to mess with the wires at all. the filter should be before the Air mass sensor.
Old Aug 4, 2002 | 09:35 PM
BEDAN_00's Avatar
the air mass sensor is attached to the stock air box.
Old Aug 4, 2002 | 09:42 PM
Rotarius's Avatar
I installed a cone filter on a `87 na and a `88 10thAETII and they both got hp gains. I still dont understand your situation U may want to be more specific.
Old Aug 4, 2002 | 09:47 PM
Rotarius's Avatar
Theres 2 air lines on the bottom of the air tube bettween the AFS anthe throtle body are those on? Also the clamps holding that tube should be securely fastened because is theres any air leaks there; the AFS may be getting wrong information to the CPU and causing your car to stall, Chech that.....Ev
Old Aug 4, 2002 | 09:55 PM
CNYRX7tech's Avatar
Exclamation 30sec run then stall
Bedan,
Did you dis-connect the AFM ? If you did download the FSM (factory service manual) and test the AFM (air flow meter) I once had this and found it to be a out of limit fuel pump switch, But PLEASE test don't guess.
Old Aug 4, 2002 | 09:56 PM
TRURX7's Avatar
Did you take the screws off? I hope you didnt take them off the connector, if you did go post a WTB AFM in the 2nd gen specific or go to ebay.
Good luck
TRU
Old Aug 4, 2002 | 11:33 PM
black7's Avatar
Good luck
TRU
LOL
Sounds too familiar. This happened to my friend last week he had another guy helping him with the car and he unscrewed it to take it out. Then he had the same symptoms you are describing.
Old Aug 5, 2002 | 04:16 PM
BEDAN_00's Avatar
where do i download the FSM and how do i test the AFM?????????
Old Aug 5, 2002 | 04:28 PM
BEDAN_00's Avatar
TRU.... what are the screws your talking about ?
Old Aug 5, 2002 | 05:46 PM
Aaron Cake's Avatar
Engine, Not Motor
Are you sure the AFM plug is in securely? If it isn't, it will produce exactly the same symptoms you mention.
Old Aug 5, 2002 | 05:47 PM
RylAssassin's Avatar
Holy **** i almost took those screws off when i put my aftermarket filter on, lol
Glad i was too lazy
Old Aug 5, 2002 | 07:25 PM
CNYRX7tech's Avatar
Factory Service Manuals
Bedan,
go to www.fc3s.org for the downloads. good luck
Old Aug 5, 2002 | 07:30 PM
BEDAN_00's Avatar
is the AFM plug the one under the air box??? if so, it is just the way i found it.... i pushed it in until it clicked in, it's as tight as it will go. Thanx for all the help. I'll check out that website.
Old Aug 5, 2002 | 09:21 PM
silverrotor's Avatar
When I built a cold air box for my n/a, I forgot to plug in the clip to the AFM. I would start It then It would die. Again and again. Realized after a minute that the clip needed to be plugged.
Old Aug 5, 2002 | 09:41 PM
TRURX7's Avatar
The screws are the ones that 'seem' to hold the electrical plug to the AFM. I took them off by accident because I did not see the clip.
So then I proceeded to the WTB section.
R.O.D
34
Jan 6, 2016 12:09 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
