acceleration stops flat out at 4000 rpms
Old Aug 4, 2002 | 08:19 PM
jacobcartmill's Avatar
just dont care.
i just took out my air pump and this seemed to be the start of the problem. i already had my cat off and the air pump still on there blowing fresh air under the engine... anyways, we took off the air pump and now when i accelerate, the rpms stop at 4000 rpms and it just stays flat and the BOV blows air out and the rpms dont raise after that and the car sounds like its bogging. anyone heard of this problem? car is an 87 T2 79k miles thanks guys. -jacob
Old Aug 4, 2002 | 08:24 PM
NZConvertible's Avatar
I'm a boost creep...
Sounds like the secondary injectors aren’t firing. They come in at 3800rpm, and since they both then fire at half the duty cycle the primaries were running at before switchover, without them there’s only half the gas going in that the engine needs. Check all the wiring leading to the injectors.
Old Aug 4, 2002 | 09:09 PM
just dont care.
thats what i thought, but how could i have messed that up when i took out the air pump? you dont think it had anything to do with that?
Old Aug 4, 2002 | 09:18 PM
Rotarius's Avatar
Hopefully the TPS was connected or not?
Old Aug 4, 2002 | 09:52 PM
Originally posted by jacobcartmill
...how could i have messed that up when i took out the air pump?
Dunno, it does sound odd. Double check you haven’t knocked any wires off somewhere. Could just be a weird coincidence, I’m not sure what would actually stop the secondaries from working other than an ECU problem.
Old Aug 4, 2002 | 09:54 PM
TRURX7's Avatar
Do you have an FCD?
If it only does it when your boost gauge goes up then cuts out, then you NEED an FCD.
Sorry if you already have one.
If you dont, you can make one. Its an involved process and I hope your know how to read schematic diagrams.
Heh
Lata
TRU
Old Aug 4, 2002 | 10:45 PM
just dont care.
yeah, the TPS was/is connected. i will try resetting it tomorrow to see if that helps my problem. and yeah, i have an fcd
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
gabescanlon
Sep 5, 2015 12:09 AM
rx7shirley
Sep 2, 2015 02:11 PM
