carb rebuild problem
Old Aug 4, 2002 | 11:48 AM
jr69187's Avatar
ok i rebuilt the carb new jets hole nine yards. i bolted the thing on tightend it down. it started up but it idled at 2k and it was way to rich i had smoke comming out the exhaust. so i kill it and decided to hook up the elelctronics and see if tyhat fixes it before i mess with the idle and mixture screws. then i go to start it and it runs fuel over the top of the carb and floods. so i am now trying figure out where to the set the mixture screw before i try to start agian. there is no vacum leak. but why is there that much fuel runing over. ohh yeah one question under the peice between the two front barrels there is a ball bearing and a weight. i put them back in the way i thought they came out i put the weight last and first the ball bearing. but why i am getting this much fuel? please help? i have to get this thing running tonight.
Old Aug 4, 2002 | 12:10 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
There's a wire that needs to be hooked up to the float bowl vent solenoid. It's under and inbetween the oil injection lines.
Didja do taht?
Flooding like that has nothing to do with the accelerator pump nozzle. Could be that your needles are getting hung up.
Idling @ 2k is usually a sign that you have a vacuum leak.
Old Aug 4, 2002 | 12:22 PM
jr69187's Avatar
ok will try be back in about 10 minutes
Old Aug 4, 2002 | 12:32 PM
jr69187's Avatar
here is a pic maybe this will help
Old Aug 4, 2002 | 12:33 PM
jr69187's Avatar
and another pic
Old Aug 4, 2002 | 12:35 PM
jr69187's Avatar
And the final pic of the old carb
Old Aug 5, 2002 | 09:11 AM
damon's Avatar
did you use the same sized jets ?
Old Aug 5, 2002 | 10:35 AM
jr69187's Avatar
i got it fixed. don't ask me how but it running fine now
jr
Old Aug 5, 2002 | 02:40 PM
jeremy's Avatar
male stripper
sounded like the floats were stuck.
Old Aug 5, 2002 | 02:56 PM
jr69187's Avatar
bfh fixed it runs like top the bigger secondary jets made a huge difference in 3rd above 5k and new acclerator pump help and also sterlings mod helped.
jr
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
ZacMan
Sep 19, 2015 09:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
