s4 and s5 N/A stock clutch difference?
Old Aug 3, 2002 | 11:18 PM
rxseven's Avatar
Special Dark
Question s4 and s5 N/A stock clutch difference?
mazda has different part numbers for the s4 and s5 N/A clutches. I thought that the flywheels were the same dimensionally, the only difference being the weight.
So what is the difference between the two?
Old Aug 3, 2002 | 11:20 PM
j9fd3s's Avatar
Community Builder
i have no idea, ive used them both ways. it would be best to get the correct one for your car
mike
Old Aug 4, 2002 | 10:31 AM
rxseven's Avatar
Special Dark
The s5 tranny is the same as the older ones, correct? if so, it probably is just a sturdier clutch. The reason i ask is I am going to use an s4 motor with s5 internals and flywheel but mated to the older tranny.
Old Aug 4, 2002 | 11:15 AM
HuggyBear's Avatar
for n/a im assuming the tranny is a lil beefier for the S5 considering it made the jump to 8k redline from 7k in S4.
Old Aug 4, 2002 | 11:28 AM
rxseven's Avatar
Special Dark
Hmm..I just want to make sure that the number of splines are the same, that way I can get either depending on the best deal I can get.
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
sYnth.
Aug 19, 2015 06:27 PM
