Drag Racing Time???
Old Aug 2, 2002 | 01:17 AM
BiG WaNkLeR's Avatar
Drag Racing Time???
I'm racing my seven tomorrow and all weekend. What kind of times should I be expecting from my few mods?
I'm going to run off the header....nice and loud, hehe
Plus I put on 245/60/15's to hook up better too.
Should I burn out to warm them up like everyone else does to get better traction?
Any input would be interesting before I take off in like 5 hours. It's a 3 hour drive to the event and I can't sleep.
Thanks
Old Aug 2, 2002 | 01:25 AM
FC3AZ's Avatar
I usually dont warm up the tires or anything. At most, if they have rocks in them or something, spin them a little to clean them. Then I usually launch at about 4000, and just let the clutch out. I have got consistent 2.35 60' times this way.
Old Aug 2, 2002 | 01:42 AM
So maybe a low 16 at most huh?
The thing I don't get is how stock is like 16.8 seconds?
Old Aug 2, 2002 | 01:48 AM
FC3AZ's Avatar
Depending on the weather, you should pull low 16's. Just make sure to get a decent launch, dont ease off the line. These cars dont have crap for tq. You need to rev and dump the clutch.
Old Aug 2, 2002 | 01:49 AM
dre_2ooo's Avatar
If it's your first time ever... i'd say 16.3
Fix your 6-ports : 15.9
Learn to drive decently : 15.7
Old Aug 2, 2002 | 01:50 AM
FC3AZ's Avatar
Dre 2000, where is he getting the power to pull those times from? Does the header really do that much for these cars?
Old Aug 2, 2002 | 01:59 AM
dre_2ooo's Avatar
You must understand that the rotary engine works different from a pist0n one (well duh ). But the POWER stroke is rotating the rotor at the SAME TIME the exhaust is happening. Meaning, there is a DIRECT relation from power to exhaust. IF you free up the exhaust the power is greater.
In pist-0ns, the power has no exhaust to slow it down, except from the OTHER cylinders, and the effect isn't that great. So on a 4-banger you might see like 5hp from headers. But on a rotary you can expect a 10-15% increase in power.
Mazdatrix sells a FULL exhuast system that got 26% DYNO-PROVEN increase in HP. So, yes, headers really do "add that much" .
Here is my logic to his times:
stock = 16.5
+intake = 16.45
+headers = 16.0
+driver skill = 15.9
+pulley = 15.87
+tires = 15.8
% error = 15.6-15.85
-6 ports = 16.2
- driver skill = 16.4
% error = ~ 16.2-16.4
Old Aug 2, 2002 | 02:10 AM
FC3AZ's Avatar
Wow, then I need to get my header on my car asap. Its just sitting in my shed, with its header wrap on, and high temp black coating on it. I would like to see my times improve .2 from the header alone. That would rule!
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
