changed the heater hose and now the engine light is on
Old Aug 1, 2002 | 03:45 PM
rx_7_driver's Avatar
Question changed the heater hose and now the engine light is on
i changed my heater hose today and when i started the car the engine light came on. i think its a code 11 but i am not sure its one short flash and then one long flash wait 3 sec and the same thing agian. what is a code 11 i use to have a link to the website but i can't find it my friend said he thinks it has something to do with the intake temp sensor but i don't see how changing the heater hose (on the driver side) would case this kind of problem. the car still runs good (becides the fucked up tranny) anyhelp would be apreacitated
edit: its a 1990 n/a vert if this helps
Old Aug 1, 2002 | 04:28 PM
~bump~
have to got work and still can't figure it out
please help
Old Aug 1, 2002 | 04:31 PM
rico05's Avatar
WTB S5 N/A FC
The intake temp sensor is located very close to the heater hose connecton on the firewall. I broke my intake temp sensor when I pulled off my heater hose, and had to get a new one. No big worry, it will just cause you to run rich b/c the ECU thinks that the intake air is cold and will compensate with added fuel delivery. Check that first.
Old Aug 1, 2002 | 11:52 PM
thanks i will check first thing in the morning
Old Aug 2, 2002 | 12:11 AM
darkwaveboi's Avatar
Need donor car in Fairfax
how could he break the intake temp sensor..i replaced my drv. side heater hose, and its below the TB
Old Aug 2, 2002 | 12:21 AM
could it have just got dissconected?? i don't even know what it looks like
Old Aug 2, 2002 | 12:23 AM
Silkworm's Avatar
Has been.. hangin' around
it's a two prong connector, sits on the drivers side of the intake manifold, almost all the way back by the firewall, right near the oil filter..
Very easy to break one of those prongs.
PaulC
Old Aug 2, 2002 | 03:54 PM
just wanted to say thanks for all the help it was disconected and the prongs were bent i just bent them back the best i could and shoved the thing back on there. the engine light came right off i didn't even have to reset the puter
once agian thanks
gtcd
30
Aug 19, 2015 02:44 AM
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
