which ecu for a 20b
Old Jul 28, 2002 | 09:46 PM
which ecu for a 20b
im lookin into gettin the microtech.for 1800 dollars
i can get the ecu a base map and coils with wire loom from tito.it also has a controller and windows compatible.but im also lookin at the link system which is llokin pretty awesome.which would u prefer?
also could someone teach me how to tune?i mean how do u know where to put negative or plus numbers where?for fuel and timing?
Old Jul 29, 2002 | 04:57 AM
HWO's Avatar
HWO
inteligent extratarestril
Dont be fooled, If you are playing with a 20B dont take shortcuts on the efi system. Realistically you should be looking at either a Haltech or Autronic system.
Link are cheap, they dont have good correction maps. A LOT of local cars here run them on 2L turbo 4wd rally cars, they are alright but i wouldn't use one myself if i had to pay for it.
Old Jul 29, 2002 | 06:02 AM
The_HITman's Avatar
I would add that if you need to ask how to do tuning then maybe an adjustable ECU is not for you.
Take it to someone who knows what they are doing and you trust them, and maybe look at running the ECU they use so that you know it will be set up properly.
Old Jul 29, 2002 | 12:24 PM
the reason im asking is cuz i wanna learn.i wouldnt try to tune it now.i want to learn first then crack a couple of eggs to make a omelet.and y not link?pettit uses link and it runs great.i dont like haltech.havent heard too much on the autronic.i guess ill be going with the microtech.
Old Jul 29, 2002 | 04:47 PM
KraftDinner's Avatar
Why don't you like haltech? It's one of, if not THE, most popular EMS company for rotaries in North America.
Wolf3d systems control 20B's well, so does Electromotive TECII's, I'm not sure but I think motec sells one for 20B also.
Old Jul 29, 2002 | 05:56 PM
Evil Aviator's Avatar
Rotorhead
Bingo. Just about any EMS will run a 20B.
Old Jul 29, 2002 | 08:40 PM
ive thought heavily about the tec 2 also,even maybe a tec 3 ..but does it come with a datalogit or handheld system?
Old Jul 29, 2002 | 11:14 PM
10sec rx7's Avatar
Any ECU will run a 20B but the only one that can do leading/trailing split with 6 ignation outputs and 6 injector outputs is the Microtech MTX12.
Old Jul 30, 2002 | 07:56 AM
rx7tt95's Avatar
Photo Diety
AND the Microtech guys have maps for just about ANY setup that you'd be using with a 20B. I think I may have a cheaper source for the Microtech too, Twin. PM me.
Michel
Old Jul 31, 2002 | 01:03 AM
HWO's Avatar
HWO
any ECU needs to be tuned by someone in the car itself if you want optimum performance........
Old Jul 31, 2002 | 04:54 AM
10sec rx7's Avatar
HWO,
True but the base maps will allow you start and run the car whit out the fear of blowing it up, the maps are rich and retarded timing,
Old Jul 31, 2002 | 06:22 AM
HWO's Avatar
HWO
You can get 20B base maps from HITman with a similar state of tune, or is that gonna blow up because its a Haltech and they have really inaccurate timing ya know......... just see the other thread about it hahaha what a f'king joke
Old Jul 31, 2002 | 07:44 AM
10sec rx7's Avatar
Hwo,
im not going to get into a bashing war with you about ecus, the fact is a haltec and autronic cant do leading trailing split on a 20b, i couldnt care less weather they can read timing properly,
Old Aug 1, 2002 | 01:17 AM
HWO's Avatar
HWO
I thought it had been agrees that unless you need to pass emissions then you dont need split timing?? as firing them both together yeilded more HP
Old Aug 1, 2002 | 01:26 AM
10sec rx7's Avatar
That depeds on who you listen to, i havent tryed it so i dont know, some people say yes some people say no, so if youve got it use it!
Old Aug 1, 2002 | 05:57 AM
HWO's Avatar
HWO
RICE makes 472rwhp from a 13B with autronic which cant do split timing on a 2 rotor............
i think his monster HP PPT is running similar set up
Old Aug 1, 2002 | 08:03 AM
10sec rx7's Avatar
Where's this monstor HP PP turbo, lets see pics and dyno sheets,
Old Aug 2, 2002 | 10:22 AM
rx7tt95's Avatar
Photo Diety
The whole split timing thing...to do it or not to do it, I don't know....many on the list say that it isn't needed and large hp gains are to be had without it. Yet looking at the Downing 4-rotor car and Spencer Racing's 3 rotor cars, they all run a three plug configuration and a Motec computer. At Daytona, I watched as their tech plugged in the laptop and did a bit of tuning. While I did not get a closeup look at the timing charts, there were multiple timing charts there which would suggest they are running split.
Michel
Old Aug 2, 2002 | 01:41 PM
j9fd3s's Avatar
Community Builder
if you wire the motec the way they want you to on a 3 rotor it is phisically impossible to to split
mike
Old Aug 2, 2002 | 01:55 PM
Jeff20B's Avatar
Lapping = Fapping
20B split or no split. I'm currently deciding which to do.
Old Aug 2, 2002 | 04:13 PM
j9fd3s's Avatar
Community Builder
i thought about running a pre 73 front cover and having 2, 3 clyinder distributors
mike
Old Aug 2, 2002 | 11:41 PM
DELTA_Rotary's Avatar
Bourbon King
The Motec M800 is supposed to run the 20B well right? I would hope it would run the space shuttle for 4k bucks.
Old Aug 3, 2002 | 04:29 AM
HWO's Avatar
HWO
Cant recall who said it but someone of this forum reckons the 26B Le Mans Motor was firing all 3 plugs at the same time...........
Old Aug 3, 2002 | 10:38 AM
j9fd3s's Avatar
Community Builder
yeah you want that ecu, just call nippon denso
mike
Old Aug 3, 2002 | 11:32 AM
Rotorhead
mike
Things change all the time, especially in racing, but the last time I saw the Kudzu (Rolex 24), it was running a single M800 firing the plugs simultaneously.
