Old 04-17-09, 05:37 PM   #1
Force13B
Respect the hat!
Force13B's Avatar
Trader Score: (8)
Send a message via AIM to Force13B
Fuel Pump write up with pictures
I found a few write ups but none with pics so here it is
Disconnect your battery. Then the fuel pump access door is behind the Driver on a USDM spec FD. Lift up the carpet and you'll see it. If you have a Bose stereo system you'll probably have to remove it. There should be 4 screws holding the door down.
Lift up the fuel door and unclip the wiring harness
You can either unclip the ground or unscrew it i went with unscrewing it.
Set the door off to the side and unscrew the fuel line connectors
Clean off the area for obvious reasons
Take all the screws out of the fuel hatch
You'll need to push the 2 fuel lines out of the way. The line on the right hooks into a clip i found it easier to pull the line of the clip so you get more play in the line
Lift out SLOWLY as to not hook the float on anything
Remove the screw on the back of the rack, mine was extremely tight
The + and - wires are different sizes so you can't really screw that up but hey maybe you can. I left 1 wire on just to make sure i didn't
With the new fuel pump make sure and hook up the fuel bag thing
by pressing on the washer
Put the spacer and O-ring in the fuel neck
Force13B is offline   Reply With Quote
Old 04-17-09, 05:37 PM   #2
Force13B
Respect the hat!
Force13B's Avatar
Trader Score: (8)
Put the fuel pump space and cover on the fuel pump
Tadaaa
Put it all back in the car and start her up. I let my car idle for quite a while to make sure there was no air in the fuel lines.
Please add in anything i might have forgotten.
Old 04-17-09, 06:08 PM   #3
MX722
2 Rotors of Fury
MX722's Avatar
I like it!
Good write up
MX722 is offline   Reply With Quote
Old 04-17-09, 09:03 PM   #4
Sgtblue
Viable fossil
Sgtblue's Avatar
Great write-up. Thanks for going to the trouble. Good point on cleaning the area around the hoses and hatch before removal.
My only comment would be to make sure you also get a new screen ("fuel bag thing"). I assume the FD is like a couple of other cars I've had this experience with, where the screen is purchased separately. Personaly I wouldn't install a new pump without a new screen...especially since they're usually less than $10.
Jim
93 VR R1
How's that "Hope and Change" workin' out for ya?
Sgtblue is offline   Reply With Quote
Old 04-18-09, 06:36 AM   #5
evot23
Darkside LS6
evot23's Avatar
Send a message via AIM to evot23
Excellent write up. Should go into the tech archives as a sticky.
Eddie
evot23 is offline   Reply With Quote
Old 11-06-09, 07:57 PM   #6
FlyFD
New Member
This write-up was extremely helpful!
I used the procedure here to replace my fuel pump today and now my FD running again!
Nothing was unexpected, I really can't thank you enough for the time you spent to post this.
FlyFD is offline   Reply With Quote
Old 11-06-09, 10:51 PM   #7
grimple1
Turd Ferguson
grimple1's Avatar
Send a message via MSN to grimple1 Send a message via Yahoo to grimple1
nice work. +2 for sticky status
ASpec GT3574, Lucky7Racing Rebuild, Banzai Racing, Automatic
grimple1 is offline   Reply With Quote
Old 11-07-09, 02:43 AM   #8
Needless!
Rotorite
this is great, to bad you didnt post this like 2 years ago lol, that would of saved me alot of trouble,
Needless! is online now   Reply With Quote
Old 11-07-09, 05:04 AM   #9
spekdah
spekdah's Avatar
so , this is for replacing your stock FP with an aftermarket?
spekdah is offline   Reply With Quote
Old 11-07-09, 12:43 PM   #10
FD3S2005
SideWayZ The Only Way
FD3S2005's Avatar
Send a message via AIM to FD3S2005 Send a message via MSN to FD3S2005
yes, couldnt you tell? stock one was piss yellow and the new one is silver?
Mods: Streetport, Fluidyne Rad, DP, rx7store mid res, Rb Duel tip, BNR Stage 3 Turbos, PFC, nippo Fuel Pump, blaa ALL BOLTONS
Help donate for my brother girlfriends brother anything will help... read about it here
FD3S2005 is offline   Reply With Quote
Old 11-10-09, 03:16 PM   #11
Force13B
Respect the hat!
Force13B's Avatar
Trader Score: (8)
No problem when i was going to change mine i searched for a write up but didn't find much so figured i'd make one.
You can replace the stock FP with another stock FP but I put in a Supra pump same size as the stock pump, this would also work for a walbro.
(\_/)
Be afraid, for Bunny doest ponder your death day.
Old 11-10-09, 03:45 PM   #12
tt7hvn
tt7hvn's Avatar
Send a message via AIM to tt7hvn
awesome writeup, pictures speak a thousand words
did you also rewire the fuel pump mod?
____________________________________________
1993 CYM R-1
1988 10th AE--new project
tt7hvn is offline   Reply With Quote
Old 11-10-09, 03:56 PM   #13
Force13B
Respect the hat!
Force13B's Avatar
Trader Score: (8)
I did but later on when i had my haltech installed. Didn't think to take pics of that had to many other wires running around.
(\_/)
Old 11-10-09, 05:17 PM   #14
tt7hvn
tt7hvn's Avatar
^ i know how that is
did you notice any difference?
1993 CYM R-1
Old 11-11-09, 08:37 PM   #15
FD3S2005
FD3S2005's Avatar
yea i have wires going crazy because of my AI system, last thing i wanted was more wires running around, so i kept all the wires under the fuel pump cover (not in the tank)
i was also looking for pictures of the fuel pump rewire mod, i wanted pictures before i worked on it, i ended up getting some, some helped a little but when i got to do it all it wasnt tooo bad but i did wish there were better pics
here was my thread http://www.rx7club.com/showthread.php?t=870523
Old 11-11-09, 09:25 PM   #16
Force13B
Respect the hat!
Force13B's Avatar
Trader Score: (8)
Since i went from a Pettit Ecu with stock twins to a Standalone with custom fuel map, all emisstions removed, 99 spec twins running non sequ yeah i notice a difference but not in the fuel pump rewire
I have a fuel kit and AI next to do on my list.
(\_/)
Old 11-11-09, 10:22 PM   #17
FD3S2005
FD3S2005's Avatar
i went with a cooling mist unit, i think if i could go again i would go with aquamist, they seem to make the unit alot smaller, so you can hide it lol.. i got the one with the gauge, its good to have i guess, tells me either boost/what % the pump is pushing/volt/ or flow rate if i had that thing for it.
Old 11-12-09, 12:54 AM   #18
Force13B
Respect the hat!
Force13B's Avatar
Trader Score: (8)
Yeah i'm looking at going with an Alkycontrole meth kit. I'll do a write up when i install that that should be fun
(\_/)
My Fuel Cut Switch write up with pictures! The Spyder 2nd Generation Specific (1986-1992) 36 10-26-08 07:29 PM
Fuel pump rewire write up? hsitko 3rd Generation Specific (1993-2002) 2 08-07-06 06:05 PM
Fuel Pump Install Write-Ups? MazdaRx7Racer4Life 2nd Generation Specific (1986-1992) 13 05-20-04 01:30 AM
Anyone have the link to the fuel pump rewire write-up? cloead 2nd Generation Specific (1986-1992) 7 10-09-03 11:12 AM
walbro 255lph fuel pump write up plz... darkwaveboi 2nd Generation Specific (1986-1992) 3 05-30-02 01:24 AM
