Old 09-04-07, 12:43 PM   #1
dj55b
Living a Rotary Dream
dj55b's Avatar
Position of Arrow On Strut Top location for referencing front end alignment
I think this should be Archived, This is a picture showing where the location of the arrow is on the strut tower tops. Also I have included a picture of how Stock location and what I think Kentetsu says is max camber. The arrow pointing would be when looking at the car top down and facing the front. If I did this wrong can someone correct this to have it archived. Thanks
Sam
Name:	Bumper Lights.jpg
ID:	256395   Click image for larger version
85 GSL, SP 12a, SDJ headers, 2.5" SS pipe with magnaflow and borla, Walbro 255lph, Mallory 4309, 47mm Fuji Racing IRTB, SS brake lines, 15x8 Kodiak rims , Tokico Strut, Eibach Springs, Carputer with touchscreen, Megasquirt, McLaren SLR green paint.
dj55b is online now   Reply With Quote
Old 09-04-07, 01:54 PM   #2
OldSchoolMel
Strictly Old School
OldSchoolMel's Avatar
I think steve posted the specs from mazda. thats a good one to add to this thread.
OldSchoolMel is offline   Reply With Quote
Old 09-04-07, 02:47 PM   #3
Kentetsu
Older I get/Faster I go!
Kentetsu's Avatar
Send a message via Yahoo to Kentetsu
Actually, the way I understand it, the arrows would point toward the rear/inside of the car for max camber/caster. If I'm reading your diagram correctly, you have this listed as the stock location...
I don't recall the exact location of mine originally, but they were definitely pointed toward the outside of the car. When I adjusted them to the inside, the difference in handling was quite noticeable...
Normally, this adjustment would be made to set the camber/caster to what a shop would consider "stock alignement". But when adjusted to provide max camber/caster, you can get an improvement in front end "bite" when entering corners. This is not exactly useful for daily drivers, and may even lead to excessive tire wear, but if you race then you'll want to check it out.
Kentetsu is offline   Reply With Quote
Old 09-04-07, 03:00 PM   #4
justint5387
CPS Motorsport
justint5387's Avatar
How much camber can you get with this strut top mod? When I was still using the stock top, the most i got was -1. -1 shouldn't wear out the tire that bad.
84 GS (CSP Auto-X/Track)
GSL-SE 13B, GSL-SE brakes and rear end, Weber 48 IDA, Aluminum flywheel, RB 4-puck clutch, RB SP exhaust, GC camber plate/coilovers (350/175), Tokico Illuminas, RB FSB, RB SS lines, 13x10 w/ 255 Hoosier A6
justint5387 is offline   Reply With Quote
Old 09-04-07, 05:42 PM   #5
REVHED
Hunting Skylines
REVHED's Avatar
The top diagram shows maximum camber and caster. The bottom diagram shows maximum camber and minimum caster.
Series 3 Rx-7 - S5 13BT, street port, 3mm seals, light flywheel, brass button, hybrid turbo, FMIC, twin DP, 3" exhaust, Microtech, big fuel system, worked suspension, LSD.
REVHED is offline   Reply With Quote
Old 09-05-07, 10:10 AM   #6
Re-Speed.com
RX7Club Vendor
Re-Speed.com's Avatar
Agreed.
-billy
Re-Speed.com is offline   Reply With Quote
Old 09-05-07, 10:17 AM   #7
dj55b
dj55b's Avatar
Thanks for the response people .. I was really just kinda guessing. What is the stock location then? Just for furthur reference and get this archived.
difference between having front strut bar only vs. rear strut bar only coldfire Suspension/Wheels/Tires/Brakes 33 09-27-08 12:11 PM
Front-end alignment Mschafe 1st Generation Specific (1979-1985) 3 01-21-05 02:56 AM
Front Pulley Alignment gonzz 2nd Generation Specific (1986-1992) 2 04-01-04 10:28 AM
front pulley alignment gonzz 1st Generation Specific (1979-1985) 0 03-31-04 01:25 AM
Screw that will let the car run or die, has label L with an arrow and R with an arrow sonic7 2nd Generation Specific (1986-1992) 4 12-24-02 03:45 PM
