Old 08-27-07, 08:14 PM   #1
rx7learner
Never stop learning
rx7learner's Avatar
Slight idle bounce < 100 rpm... why?
I installed a mikuni 44 sidedraft and had a very slight bounce in rpms at idle < 100rpm difference barely noticeable on the tach but audible, I just did a master rebuild for my carb I bought from Wolf Creek Racing and confirmed with them all my jetting is correct for a stock port 12a.
I purchased and installed new ngk plugs
New wires
checked spark on each wire... ok
I have a small booster vac leak so I disconected and capped the outlet on my intake to make sure that wasnt the problem (still bouncing)
Set timing from stock up to 24L 16T adjusting mixture along the way (still bouncing)
worked from 3.5 psi on my fpr to 5 psi and back and still bouncing!!!
checked bolts on intake to engine and carb to intake... all tight... bouncing...
I have 83K on my 12a and I baby her... her oil is changed whenever it starts changing color and shes never gotten hot....
I may be nit picky but what can cause this bounce besides what i have checked so far?
Was thinking about sea foaming when I get down to an 8th of a tank?
Any other ideas please let me know.
BlowThrough12A/RBSP Exhst/BoostPreped Mikuni/GSLSE FP/ RRFPR/FPG/2GCDIFS/MSD6A/FMOC/NPR FMIC/PLXM250 Wideband/Boost/Oil Temp/Oil Pres/Water Temp SPI Guages/RB 3"DP/RB Racing PP/
rx7learner is offline   Reply With Quote
Old 08-27-07, 08:40 PM   #2
FCKing1995
Rotary Slave
FCKing1995's Avatar
Send a message via AIM to FCKing1995
My mikuni does this also. I just took it as normal and lived with it. Plus it gives it a slight BP sound anyway Atl east with a RB Streetport system.
-87' Turbo II
-83' GS
-94' Miata R package
-84' G-
-91' Accord (the turd)-
FCKing1995 is offline   Reply With Quote
Old 08-27-07, 09:09 PM   #3
rx7learner
Never stop learning
rx7learner's Avatar
funny... thats what i have... an rb streetport system....
guess i'll just live with it also.... thanks
btw... i wish the search function used the same algorithm as the bottom of this post uses for similar threads... it seems to find more acurately.
So i Got an S5 slight idle problem rx7ofdoom 2nd Generation Specific (1986-1992) 9 07-09-05 04:37 PM
slight stumble from idle.... smg944 Power FC Forum 2 06-06-04 11:26 AM
Slight surge in idle Fd3BOOST 3rd Generation Specific (1993-2002) 11 04-21-04 08:40 PM
slight hesitation from idle cavellm 3rd Generation Specific (1993-2002) 8 02-11-03 10:57 PM
Idle bounce! GTUsGUY 2nd Generation Specific (1986-1992) 20 08-12-02 08:18 PM
